It's not gonna work...
Some conversations generate light. Some generate heat. Some generate neither.
Quote, originally posted by Rien » |
If I have been told correctly the blocks are the same for the most part. If this is so. then the 1.8t should mount in to exsisting mounts and hardware. |
Nopeity-nope. The 1.8T has entirely different engine mount bosses. You are in for--wait--
I am in for--either fabrication or construction of a hybrid engine. I know which route I am taking.
A little fab work WILL be nessecery( Could I get a SP on that word Tera?). |
Check out that nifty ABC button on your make-a-post screen. It's to the left of the Quote button and to the right of the Image button. Cool, isn't it?
Actually, a LOT of fab work is nesessary. The Audi A4 suspension is so radically different from the Fox and early Quattros that a whole new chassis would be the fastest and possibly cheapest means of getting this done with A4 suspension. Once I saw the A4 suspension, I decided that a different approach would be better. My
original concept, from years ago, for an AWD Fox was a Quantum Syncro drivetrain and an engine adapter. The QSW rear end would be a
much better fit for the Fox's rear body. Now, because of the scarcity of shops willing to make a one-off engine adapter, as there is no other use for a 4-cyl engine-to-5-cyl trans adapter, I think the best way would be QSW suspension front subframe and Audi A4 1.8TQ drivetrain. This would require the following mods to the chassis, provided one would stick with the cost-ineffective approach of modifying the existing chassis (please remember, this list is far from complete):
1) Five custom driveshafts
2) Movement of the upper spring positions outward to maintain suspension geometry
3) Front subframe fitment (welding in of new bosses to accept subframe)
4) Engine-to-subframe fitment (5-cyl mounts are different from 4-cyl and 1.8T mounts.)
5) Possible modifications to the subframe to fit the 1.8T oil pan
6) Complete front-to-rear roll cage, as the Fox was never designed to have drive stresses spread across the whole chassis, not was it intended to have 300+ HP
7) Race fuel cell moved somewhere other than factory location to allow fitment of rear end
8) Completely new center hump! You have to fit a driveshaft AND a big exhaust down the center now. You also have to build a new mounting location for the shift linkage.
I'll stop there. Unless you can do it all yourself, this is a $30K project--and that's my cost. I know lots of experts who would help me as much as possible--a Chassis builder, an engine developer, exhaust people, cheap parts sources even for more exotic stiff, like a complete A4 1.8TQ drivetrain, a complete QSW suspension and a nice rust-free Fox good for cutting and welding. (Rusty cars aren't fun to cut and weld.)
