The purpose of this thread is to act as a running reel of products we offer for the Mk5 Jetta 2.5L / Jetta 2.0T and associated content!
The AWE Tuning Mk5 Jetta (2.5L and [URL="http://www.awe-tuning.com/awe-tuning-mk5-jetta-2-0t-performance-exhaust-suite"]2.0T[/URL]) Exhaust Suite
Touring Edition:
Engineered to perfection, the Touring Edition Exhaust is designed to give your Jetta 2.5L and 2.0T a more aggressive, yet sophisticated tone. The Touring Edition Exhaust features a resonated midsection and replaces the large stock rear muffler with a straight-through resonator featuring AWE Tuning’s proprietary drone-canceling solution, 180 Technology™.
Sound Perfection: AWE Tuning 180 Technology®
As exhaust gases exit the Jetta’s engine and flow into an 180 Technology equipped resonator, they pass through strategically located ports, and into reflection chambers. Sound waves, carried by these exhaust gasses, bounce off the walls of the reflection chambers. By controlling the size and location of the ports and the chambers, we also control when the sound waves exit the chambers. The specific timing of when the reflected sound waves rejoin the main exhaust flow creates a one-hundred-and-eighty-degree out-of-phase sound wave that cancels out problematic frequencies.
More on AWE Tuning 180 Technology™ can be found right this way.
Track Edition:
Featuring a straight-through design, the Track Edition Exhaust revamps the Jetta attitude by replacing the rear 180 Technology® resonator with a straight pipe section, providing a more pronounced, aggressive tone in the mid range without being boomy in the cabin. This product cannot be returned or exchanged based upon volume preference!
Tip Options:
All tip options include the AWE Tuning logo, and double walling to ensure a mirror finish even under hard usage. All tips are individually adjustable, allowing depth into the bumper to be set according to personal taste.
Complete AWE Tuning Touring Edition or Track Edition Exhaust, all necessary hardware (factory sleeve clamp to be re-used), and two 90mm slash-cut tips in chosen color.
You’ve got questions? I've got answers. Hit me here via PM or direct using the email below!
eace:
- Max gains of 8 hp to the crank (2.5L), 20 hp and 14 ft-lbs of torque to the crank with full turbo-back (2.0T)
- Touring and Track Editions available
- Touring Edition features AWE Tuning’s proprietary drone-canceling solution, 180 Technology®
- Handcrafted from 2.5” CNC mandrel-bent T304 stainless steel
- 2.0T Performance Downpipe features 200 cell HJS catalyst (for racing use only)
- Direct bolt-on
- 90mm double-walled tips adjustable tips available in polished silver or diamond black
- Engineered, designed, and manufactured in-house at AWE Tuning
- No Check Engine Light - guaranteed
- Perfect fitment - guaranteed
- Featuring the AWE Tuning Lifetime Exhaust Warranty
Touring Edition:
Track Edition:
Tip Options:
- 90mm slash-cut Diamond Black tips
- 90mm slash-cut Polished Silver tips
