21 - 40 of 49 Posts
Discussion Starter #22
Nice work!
hey thanks, man
This is a super cool manifold.
Any reason your using a side entrance throttle and not making it rear entrance, so you can come directly of the turbo?
The plan is to use a single 90 elbow from turbo to throttlebody. It should make more sense visually in a couple weeks. :beer:
Discussion Starter #26
Looks great. I'm glad you made the change.
Thanks. Yeah, not all my ideas workout in practice like they do in my head.
Monday might be getting more welding. Really trying to get this thing wrapped up by the end of April.
Discussion Starter #27
Plenum halfway there:
Problems up top here though:
It did fine underneath on the other side in that same area.
Any tips for cast? My coworker is still learning aluminum.
I am no expert by all means, but I first started welding Cast AL many years ago. While I saw you are using Thoriated (based on prev page), I have had more luck on Cast with either pure Tungsten (non-Inverter), Ceriated or recently Lanthiated
BUT, with that being said, it really looks like you just have contaminated Cast. Cast, will absorb oils. Non-Chlor brake cleaner and pre-heat will usually vapor off the contams. Glass Beading will also make your like easier with cast!
Discussion Starter #29
I think you're right about the contaminated cast. I'll try pre-heating and non-chlor brake cleaner. :thumbup:
Discussion Starter #33
Discussion Starter #38
.25 is nuts for end tanks. I typically use .090. the best kind of kill is Overkill lol.
Looking good. If you still need to weld to the cast section, cleaning up the surface with a carbide Burr bit, file, or mill really helps. In addition to the absorbed contaminates, the surface finish off raw cast doesn't easily allow for oxide removal and can cause subsurface porosity.
21 - 40 of 49 Posts
