1 - 20 of 20 Posts
So im installing my coilovers on the passanger side and the brake part went to far and the axle poped out of the HUB now the car does not drive ahhhhhhh Can i just pop it back in or what man this is stupid lol. HELP ME OUT
Re: axle poped out of the hub (tyrolkid)
Quote, originally posted by tyrolkid »
if it's the inside joint you're talking about, pop it back in...
hopefully i can i just got back from work and im going to try. Anyway its the shaft part poped out of the hub or whatever its called because the brake part leaned way to far you kinda know what im syaing hopefully someone does so they can HELP ME should of just payed someone to install the coil's lol
Re: axle poped out of the hub (2001GTi18t)
it should just pop back in.
you might need to persuade it a little with a BFH and a block o wood.
Discussion Starter · #6 ·
Re: axle poped out of the hub (VDUBNDizzy)
Quote, originally posted by VDUBNDizzy »
Where's the 30 mm 12 pt axle nut?
I have that. Ok so i poped it back in a total MESS I turn the wheel and the axle and wheel ALL MOVE so im think coo i fix it NOT. I start the car in nuetral i hear and axle spin but the car not MOVE WTF is going on if the car is in the air and i start the car the wheel spins. I drop it to the ground and it doesn't MOVE and any gear, i hear a little grinding MAN what the hell did i do
Discussion Starter · #7 ·
ANYONE know what im taking about
take some pictures for us
take a breath
take the car to someone who can do something to your car without breaking it
Banned
Re: axle poped out of the hub (germanrox)
Quote, originally posted by germanrox »
Or learn to explain what you are asking a little better.
Discussion Starter · #10 ·
Here's a pic not my axle but a pic, this came out. I put it back in, but it still doesn't work AXLE, HUB spins, when wheel is in the air it spins, but when i set it down it doesn't move it makes a grinding noise and my MPH go up but the car isn't moving
Discussion Starter · #13 ·
Re: axle poped out of the hub (Patrick Schmidt)
Quote, originally posted by Patrick Schmidt »
yeah, that's broken. go get a new joint.
Mine is not broken like that. CV joint i took it out and put it back together but it still doesn't work
LOL oh well i'll try to find a cheap used passanger axle
Banned
You took it out and "put it back together"?
You really need some lessons on communication man.
You don't read Engrish? yeah, me neither.
Discussion Starter · #16 ·
LOL it popped out when i was putting the coilovers on, yeah im not from this country my english sucks i know. I'll just buy a new axle anyone want coilovers or a chip both for sale
Discussion Starter · #18 ·
alright, sorry to bag on you.
which part popped out? is the axle nut and outer joint still in the hub?
the axle part that pipe thingy. when i was putting the coils on the brake bent pretty far and it popped out . Man im just frustrated guys sorry. I will try couple more times to see whats up. the CV joint was still connected but i removed it to re attach the axle back in the CV or HUB whatever its called so the wheel can spin. So i did and the wheel spins but when i set it all on the ground and try to drive it, the MPH goes up but the car doesn't move and i hear the axle spinning but nohting moving
Banned
I've said this before but I'm sorry to say it again. YOU DON'T KNOW WHAT YOU ARE DOING AND SHOULDN'T BE WORKING ON YOUR CAR. Either sell it or get a mechanic.
do this. get the opposite side of the car in the air, and put it in gear. pop the axle shaft back into the joint. have someone spin the opposite wheel while you hold onto the broken joint. if you can hold it, your **** is busted. if it torques your arm, you are good to go. pop it back in the hub and hammer it down with a breaker bar.
as a side note, there's a circlip you have to defeat to get the outer joint to reseat. it's going to toake some whacking with a hammer. make sure the axle nut is in place so you can rethread it once reinstalled in the hub.
1 - 20 of 20 Posts
