1 - 10 of 10 Posts
Hey guys i got an oil leak, not a big one... and i was told it was the valve cover not the head gasket, so when replacing that... is there anything i should replace along with it? and price range ( w/o labor thats a fixed rate
) tanks!
Re: (TheGentleArt)
I haven't done that job yet, sorry. But you'll have to remove the intake manifold, so have a gasket for that as well as the VC gasket. Be extra careful disconnecting the PCV breather, it may fall apart in your hands. You may have read the other threads regarding that part.
Discussion Starter · #4 ·
i wont be doing the labor... i have a mechanic
he does good work.. just tryin to figure out what parts ill need. thanks
Re: b4 Vavle Cover Questions?? (TheGentleArt)
I was told the same thing, I've got a bit of oil that comes up from the cover http://****************.com/smile/emthdown.gif in the general area to the front of the oil cap (between the cap and the ignition wires closer to the front bumper).
I'll let you know what I find out, could you also post anything you find when you find out what you need?
Thanks and best luck
Abe
Discussion Starter · #6 ·
Re: b4 Vavle Cover Questions?? (jbrams)
yeah sure... ill post anything i find out. i did find head gasket kit for 99 bucks new and valve cover/gasket kit new for.. like about the same off vwparts.com i think. so... labor is gonna suck ass if you dont know someone... it still may suck ass lol. ill let ya know after i fix it if it clears the problem up. mine is really leakign on the left side of the motor...not in the front but ya its comming from right under the valve cover... so we will see
im buyin rims 1st F-k the oil lol
Valve cover gasket $13.12 at
http://www.germanautoparts.com/
Give them a shot I have bought all my stuff from them.... http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Modified by FrankVR6 at 9:44 PM 2-16-2004
Re: b4 Vavle Cover Questions?? (FrankVR6)
What's the labor like on replacing this valve cover gasket?
Very curious,
Abe
Here's a more direct link:
http://www.germanautoparts.com...ine=4
Quote, originally posted by FrankVR6 »
Modified by jbrams at 7:47 PM 2-16-2004
Anyone with an update on how to do this or what a shop will charge to do it for you?
Thanks!
I was quoted prices between $150-$320.
some said it was two gaskets (it's one) and wanted to charge extra hours for it (obviously, they are off my list of potential mechanics).
It shoud be less than three hundred, more than two probably. 2 hours according to their book, plus about $30 in parts.
Labor around here is $90 http://****************.com/smile/emthdown.gif
Abe
PS - I also picked up a new oil cap at the dealer for $4 just in case it was getting spewed out of there and then spreading around (suggested by the most experienced and highly recommended mechanic I talked to, cleaned the whole area and the oil cap with brake cleaner and told me to do the same a few times after driving it around . . . it the oil stops appearing then the problem was the old/bad gasket on the oil cap, if not . . . well, I just hope it's just the cap
Modified by jbrams at 9:44 PM 3-9-2004
1 - 10 of 10 Posts
