B5 Passat - Power seats into non-power equipped
1260 Views 5 Replies 4 Participants Last post by  gtidog
Would like to know if power seats from a B5 Passat would fit into a B5 that did not come equipped with them. Any info, appreciated.
1 - 6 of 6 Posts
Re: B5 Passat - Power seats into non-power equipped (gtidog)
These guys might know.
AUDI/VW of New Hampshire. 1-800-350-4590
There is a user on the Vortex, larsensa, that is in the middle of this. I helped install the seats and he is getting them wired up soon. He could probably help you out with more specific questions.
I do know that Passats without the power seats standard are not equipped with the proper wiring harness to do a "plug and play" install.
Hope that helps.
Re: B5 Passat - Power seats into non-power equipped (gpchicago)
thanks for the feedback. So, I take it that the tracks and airbag hookups ar the same? Sounds like wiring may have to be run back from the fuse block.
Keep in mind how these "GLX only" seats interface with the comfort & convenience module.
The C&C module receives a signal from the remote for three different seat/power mirror settings. It will be easy to get airbags and power to make the seats work. Getting them to work with the remote and have the mirrors adjust too will be a little more involved.
[Modified by Electron Man, 8:45 AM 2-28-2002]
Re: B5 Passat - Power seats into non-power equipped (Electron Man)
Thanks for all of the input. Good info to have.
Ended up finding a used 2001.5 GLX, so for now it's not an isssue.
1 - 6 of 6 Posts
