First of all this is a great thread with lots of ideas and answers... However I am reading this after changing my back pads (06 Passat 2.0t). I took everything off and used the method which supplies 12V to caliper motor to bring the piston in, and then simple C-Clamp action to push it in afterwards. I thought I had beat the system, as everything fit back on and appeared good- until I started the car and got the parking break fault light on dash + flashing light on button and beeping while car is in drive.
So, after reading this thread in it's entirety (and many others) I have a pretty good handle on what could have happened and what I need to do to fix it. After work today I'm going to start small and try the manual reset (unplug battery, brake for 35 seconds, push button for 10)... followed by taking everything apart again (this time with the battery disconnected) and push back in the caliper pistons, put it back together and follow the exact methods Ive seen on here- that have worked. I do have a couple questions though if anyone can chime in:
-It seems like my driver side parking break does engage and disengage and that the problem is on the passenger side... thoughts? could it be as simple as not plugging the electronic cable back in deep enough on that side?
-Would hooking up a vag com now- after the fact- be able to solve things? One of my friends has one I could get to eventually...
-If all else fails whats the next step? replace the caliper? I f**king hope not. What other alternatives are there?- motor replacement, bleed and replace break fluid system? manually set the pistons to a decent spot for driving in the meantime??? im just grasping at straws on this one...
Any help would be appreciated. Oh- also should note that it sounded like my rear pads were slightly scraping the rotors last night- i drove it around the block with the light beeping just to see where I was at.. im assuming this is from the calipers not being calibrated/reset, and that that will work itself out along with the parking break fault message.
