Bad Engine Mounts?? Please look at Pic down the chain
I have a 08 2.0T sedan with 97K that I have been chasing a "shuttering" feeling in the front end when I go over harsh bumps like railroad tracks and frost heaves that we get on roads here in NE.
At this point the front suspension has had a lot of improvements done and problem still exits.
Front suspension work over last 6 months:
- New LCA Bushings (solid rubber style rear and Whiteline front)
- Koni FSD Shocks
- VW DG Sport Springs
- 034 Density upper strut mounts
- Meyle HD Sway Bar Link
- ECS Sub Frame Bolt Kit
After all this there is actually an increase in this shuttering feeling most likely due to a firmer suspension now with new springs.
The car drive fantastic, the feeling that there is something loose up front and the shuttering feeling when hitting harsh bumps is diving me crazy.
In addition, I drove a local VwVortexer's 06 Passat that is riding low on coilovers and it did not have this same shuttering from the front so pretty sure what is going on in my car is not normal.
Completely went through front suspension last night and tripled checked that everything is tight and secure!
Also, have upgraded sub frame bolts with ECS kit and checked all the bolts to make sure they are tight and all is good.
Since after all this work and substantial $$$ investment the problem is still there, should I be looking at motor mounts ?
The engine/tranny is no where near secure sitting in the existing mounts, have noticed two things that have been this way for quite awhile.
If parking brake is not on when tightening or breaking loose lug nuts car has a lot of rock back and forth and you can see engine moving a lot if hood open.
Last night I put a large screw driver between right side mount where piece from engine goes into frame mount and I can move engine side to side with minimal effort about 1 1/2" or more.
One more thing, when coming to a slow stop at the last downshift just before you stop I get a light clunk from left side somewhere and if you slow down from 50 mph or so to 25 to 30 mph and then put gas back on you get a left side clunk too but not always.
Does it sound like bad mounts?
I can take video and post later if that would help?
- Koni FSD Shocks
