I'v just did the install of a kerrengo pressure compensator (to see if that would fix a oil spill from breather) on a VW Passat 1.4 TSI with a 7-speed DSG.
When I re-installed I tried to do a "Basic Setting" on group 060, but it doesn't seem to work as it should, something is happening on the car, but it doesn't seem to be able to succeed in the procedure.
Initially it comes up as this:
A few seconds later it shows ( 255 41 0 0 ):
I can still hear it "working" but this just stays like this - I tried waiting about 15 minutes with brakes on to no avail.
Is there now any danger of trying to get the car into gears or do I presumably damage anything (the mechatronics unit is still the original one)
Both the unit, and dsg have been filled with proper oil/level.
There is errors on the car, but not on the dsg.
Any tips on what this error might relate to and if it would be safe to try it without this succeeding would be appreciated.
Code:
Wednesday,11,August,2021,10:28:53:12859
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ3CZCE070752 License Plate: DN76689
Mileage: 125930km-78249mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4C 4F 52 53 55
56 61 62 72 77
VIN: WVWZZZ3CZCE070752 Mileage: 125930km-78249miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 BD HW: 03C 907 309 E
Component: 1.4l R4 TSI H15 9970
Revision: L5H15--- Serial number: 00000000000000
Coding: 00250032002401000000
Shop #: WSC 35443 001 1048576
ASAM Dataset: EV_ECM14TFS01103C906016BD 001006
ROD: EV_ECM14TFS01103C906016BD.rod
VCID: E2C18C56F57D0A9B35-80B6
4 Faults Found:
4344 - Please Check Fault Codes in Control Module for HVAC (J301)
U1025 00 [047] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 125168 km
Date: 2021.04.13
Time: 07:15:38
Engine RPM: 1183.50 /min
Normed load value: 8.6 %
Vehicle speed: 27 km/h
Coolant temperature: 89 °C
Intake air temperature: 15 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.913 V
Unlearning counter according OBD: 40
CAN status - engine control module-Bits 0-7: 0
CAN TimeOut meter - transmission-Bits 0-7: 0
Generator performance: 0 W
CAN TimeOut meter - gateway-Bits 0-7: 0
CAN TimeOut meter - battery manager-Bits 0-7: 0
4638 - Engine Oil Temp. Sensor (G8)
P0196 00 [047] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 122
Mileage: 125169 km
Date: 2021.04.13
Time: 07:16:30
Engine RPM: 1335.50 /min
Normed load value: 10.2 %
Vehicle speed: 23 km/h
Coolant temperature: 88 °C
Intake air temperature: 17 °C
Voltage terminal 30: 15.007 V
Acceleration: -0.583 m/s²
Fuel high pressure: control deviation: 0.1850 MPa
Height correction: 0.97089
Engine oil temperature: 88.5 °C
Oil warning threshold: 41.676 mm
Oil fill level: 54.000 mm
4629 - ECM Power Relay Load Circuit
P068A 00 [040] - Opens Too Early
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Engine RPM: 0.00 /min
Normed load value: 75.3 %
Vehicle speed: 0 km/h
Coolant temperature: 4 °C
Intake air temperature: 5 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 6.290 V
Unlearning counter according OBD: 34
Mass flow through throttle valve: 0.0 kg/h
Mean injection time: 0.000 ms
Engine operating condition: Idle
Engine operating condition-Test_Program_Channel 87: 5
18118 - Fuel Quality
P30C0 00 [032] - Inadequate
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 060 D HW: 0AM 927 769 D
Component: GSG DSG AG7 431 5273
Revision: 00043014 Serial number: CU501109215091
Coding: 0000020
Shop #: WSC 00550 218 10285
VCID: AB5F21720A378BD3C6-80FE
7 Faults Found:
006079 - Hydraulic Pump
P17BF - 000 - Play Protection - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 28
Reset counter: 10
Mileage: 125464 km
Time Indication: 0
Date: 2015.09.14
Time: 16:28:19
P17BF - 001 - Play Protection - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 28
Reset counter: 10
Mileage: 125464 km
Time Indication: 0
Date: 2015.09.14
Time: 16:28:19
P17BF - 002 - Play Protection - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 28
Reset counter: 10
Mileage: 125464 km
Time Indication: 0
Date: 2015.09.14
Time: 16:28:19
006300 - Function Restriction due to Insufficient Pressure Build-Up
P189C - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 28
Reset counter: 10
Mileage: 125730 km
Time Indication: 0
Date: 2015.09.22
Time: 10:06:24
002113 - Transmission Fluid Pressure Sensor/Switch 1
P0841 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 22
Reset counter: 9
Mileage: 125734 km
Time Indication: 0
Date: 2015.09.22
Time: 11:18:45
006293 - Functional Restriction due to Pressure Drop
P1895 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 125920 km
Time Indication: 0
Date: 2015.11.26
Time: 19:36:43
P0841 - 001 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 22
Reset counter: 9
Mileage: 125734 km
Time Indication: 0
Date: 2015.09.22
Time: 11:18:45
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AC HW: 3AA 614 109 AC
Component: J104 C2 450M VD74 0022
Revision: --H07--- Serial number: 00000004769336
Coding: 0007531
Shop #: WSC 05311 000 00000
VCID: EED9E866F9A5BEFBA1-80BA
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 93
Reset counter: 115
Mileage: 124763 km
Time Indication: 0
Date: 2015.08.21
Time: 09:39:57
Freeze Frame:
Speed: 52.0 km/h
Hex Value: 0x0100
Bin. Bits: 00000000 00000000
Voltage: 14.75 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0004004803
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW46.rod
VCID: 8005A6DE1B31B88B43-80D4
2 Faults Found:
9481748 - High Pressure Sensor
B10AE 14 [009] - Open or Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 79
Mileage: 125168 km
Date: 2021.04.13
Time: 07:15:32
9479189 - Signal Line for Air Quality Sensor
B10A4 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 161
Reset counter: 116
Mileage: 125169 km
Date: 2021.04.13
Time: 07:16:18
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 E HW: 3AA 937 087 E
Component: BCM PQ47 H+ 413 0455
Revision: BC413001
Coding: 000800000000000000180080540029F423D50088626D8D60E480C7240041
VCID: BC7D122E3F591C6B5F-80E8
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 29081 10 0603
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 220911 05 54 0403
Coding: 02302A
No fault code found.
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 HW: 7N0 919 475
Component: PARKHILFE 8K H04 0009
Revision: -------- Serial number: 77631126402179
Coding: 108102
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA18VW47X0000 001003
ROD: EV_EPHVA18VW47X0000.rod
VCID: FCFDD22E77D9DC6B1F-80A8
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__101 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PDG81FF
Coding: 0012337
VCID: CC9D42EEAFF9ACEBEF-8098
Subsystem 1 - Serial number: 6332MTS666552511
Subsystem 2 - Serial number: 6342MTS665462511
Subsystem 3 - Serial number: 6351HTS6197RFAKR
Subsystem 4 - Serial number: 6361HTS6B0BIFAKR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110920101475
Coding: 1992250000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: EFE7F56236AFB7F3AA-80BA
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Coding: E30000
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 870 C HW: 3AA 920 870 C
Component: KOMBI H03 0607
Coding: 161F01
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: B2613C16E51DDA1B85-80E6
1 Fault Found:
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal high time > maximum
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 79
Mileage: 125168 km
Date: 2021.04.13
Time: 07:15:29
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H41 1620
Revision: H41 Serial number: 120911F1000966
Coding: 462006
Shop #: WSC 05314 000 00000
VCID: B9730B3A306B294344-80EC
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0400
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: F6E9C00681F5863B69-80A2
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660885848
Coding: 010000
VCID: A953DB7AC0CB99C334-80FC
1 Fault Found:
03138 - Input AUX IN
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 156
Mileage: 97890 km
Time Indication: 0
Date: 2011.12.12
Time: 12:22:51
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0003563726
Coding: 0200B7
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
VCID: B56B070A1473CD23A0-80E0
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0407
Serial number: 00000002455500
Coding: 000090
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.308 1002
Revision: 1AH03734 Serial number: 00112620041101
Coding: 0000258
VCID: BC7D122EFF591C6B5F-80E8
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ47 ELV 043 0634
Coding: 0091020052830E76300494157C084F0B607801
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1620
Coding: 00000008
VCID: EFE7F5623EAFB7F3AA-80BA
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0003548363
Coding: 0200B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: B66900060975C63BA9-80E2
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0407
Serial number: 00000002466259
Coding: 000090
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000251732
Coding: 0022167
VCID: B56B070ADC73CD23A0-80E0
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 E HW: 7L6 907 357 C
Component: AFS-ECU H04 0105
Revision: -------- Serial number: --------------
Coding: 029200000B000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
ROD: EV_HeadlRegulVWAFSPt_VW46.rod
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H04 0011
Coding: 230000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H04 0011
Coding: 230000
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AP HW: 1K0 035 186 AP
Component: Radio RCD310 031 0075
Revision: 01000001 Serial number: VWZ1Z2L3755028
Coding: 01000400040011
VCID: F4EDFA0E5789942B57-80A0
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1620
Coding: 032B1864
VCID: F1E3F31A289BA103BC-80A4
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000008900524476
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660838470
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA_A01_VW25.rod
VCID: A649D046D9D5B6BB19-80F2
End-------------------------(Elapsed Time: 03:19)--------------------------
Friday,03,September,2021,14:02:57:12859
VCDS Version: 21.9.0.1 (x64)
Data version: 20210824 DS330.0
www.Ross-Tech.com
56 61 62 72 77
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
Revision: L5H15--- Serial number: 00000000000000 CVN: 83E1E220
VCID: E2C18C56F57D0A99B4-80B6
VINID: 9E69EAAAA0D3A935401C01C50895EF6BA5
2 Faults Found:
U1025 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 125931 km
Date: 2021.09.03
Time: 00:03:58
Normed load value: 0.0 %
Coolant temperature: 15 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.250 V
P0196 00 [039] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 125931 km
Date: 2021.09.03
Time: 00:05:14
Engine RPM: 724.00 /min
Normed load value: 22.7 %
Coolant temperature: 21 °C
Voltage terminal 30: 14.630 V
Acceleration: 0.000 m/s²
Fuel high pressure: control deviation: -0.0080 MPa
Height correction: 1.00293
Engine oil temperature: 19.8 °C
Oil warning threshold: 40.000 mm
Oil fill level: 0.000 mm
Readiness: 1110 0101
Coding: 0000020
VCID: AB5F21720A378BD147-80FE
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 10
Mileage: 125931 km
Time Indication: 0
Date: 2016.01.25
Time: 10:34:14
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 10
Mileage: 125931 km
Time Indication: 0
Date: 2016.01.25
Time: 10:34:14
Coding: 0007531
VCID: EED9E866F9A5BEF920-80BA
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 116
Mileage: 125931 km
Time Indication: 0
Date: 2016.01.25
Time: 10:29:38
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 11.50 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Revision: 00001004
Coding: 0004004803
VCID: 8005A6DE1B31B889C2-80D4
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 125931 km
Date: 2021.09.03
Time: 10:37:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 116
Mileage: 125931 km
Date: 2021.09.03
Time: 10:37:58
Revision: BC413001
VCID: BC7D122E3F591C69DE-80E8
Coding: 00B795
Coding: 02302A
Coding: 108102
VCID: FCFDD22E77D9DC699E-80A8
Coding: 0012337
VCID: CC9D42EEAFF9ACE96E-8098
Coding: 1992250000
VCID: EFE7F56236AFB7F12B-80BA
Coding: E30000
Coding: 161F01
VCID: B2613C16E51DDA1904-80E6
1 Fault Found:
B1041 35 [009] - Signal High Time > Maximum
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 125931 km
Date: 2021.09.03
Time: 10:29:36
Coding: 462006
VCID: B9730B3A306B2941C5-80EC
VCID: F6E9C00681F58639E8-80A2
Coding: 010000
VCID: A953DB7AC0CB99C1B5-80FC
Coding: 0200B7
VCID: B56B070A1473CD2121-80E0
Slave Driver:
Coding: 000090
1 Fault Found:
66048 - Motor for Front Window Regulator
B11EC 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 116
Coding: 0000258
VCID: BC7D122EFF591C69DE-80E8
Coding: 00000008
VCID: EFE7F5623EAFB7F12B-80BA
Coding: 0200B6
VCID: B66900060975C63928-80E2
Slave Passenger:
Coding: 000090
Coding: 0022167
VCID: B56B070ADC73CD2121-80E0
Coding: 230000
Coding: 230000
VCID: F4EDFA0E57899429D6-80A0
Coding: 032B1864
VCID: F1E3F31A289BA1013D-80A4
ROD: UHVNA.rod
VCID: A649D046D9D5B6B998-80F2
End-------------------------(Elapsed Time: 03:20)--------------------------
Friday,03,September,2021,17:11:52:12859
www.Ross-Tech.com
56 61 62 72 77
02-Auto Trans -- Status: OK 0000
2 Faults Found:
U1025 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 125931 km
Date: 2021.09.03
Time: 02:47:18
Coolant temperature: 75 °C
Intake air temperature: 37 °C
Voltage terminal 30: 12.651 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 125931 km
Date: 2021.09.03
Time: 02:47:17
Fuel high pressure: control deviation: 6.7290 MPa
Height correction: 1.00232
Engine oil temperature: 75.0 °C
Oil warning threshold: 40.500 mm
Coding: 0000020
Component: J104 C2 450M VD75 0022
Coding: 0007531
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 116
Mileage: 125931 km
Time Indication: 0
Date: 2016.01.25
Time: 00:19:56
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.75 V
Bin. Bits: 00011111
Count: 185
Hex Value: 0x0000
Revision: 00001004
Coding: 0004004803
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 125931 km
Date: 2021.09.03
Time: 00:20:26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 117
Mileage: 125931 km
Date: 2021.09.03
Time: 00:20:26
Revision: BC413001
Coding: 00B795
Coding: 02302A
Coding: 108102
Coding: 0012337
Coding: 1992250000
Coding: E30000
Coding: 161F01
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 125931 km
Date: 2021.09.03
Time: 00:18:41
Coding: 462006
Coding: 010000
Coding: 0200B7
Slave Driver:
Coding: 000090
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 116
Mileage: 125931 km
Date: 2021.09.03
Time: 00:18:41
Coding: 0000258
Coding: 00000008
Coding: 0200B6
Slave Passenger:
Coding: 000090
Coding: 0022167
Coding: 230000
Coding: 230000
Coding: 032B1864
ROD: UHVNA.rod
End-------------------------(Elapsed Time: 03:15)--------------------------
