Re: Battery Cable (ottawanker)
Ottawanker, Autotech.com have overkill alternator wiring harnesses at a reasonable price.
SPORTTUNED HEAVY DUTY ALTERNATOR WIRES
Autotech now carries a heavy duty upgrade to replace or supplement the thin, corrosion-prone stock alternator wire on your VW. These new high current wire harnesses are easy to install and will benefit any VW's charging system. High current loads from Euro headlights, stereo power amps, radiator fans, etc. gradually corrode the stock alternator wire, reducing its ability to flow current to your battery. We have seen failing alternator wires reduce the output of a perfectly good 90 amp alternator to a mere 40 amps!
Autotech SportTuned alternator wires are built to last. Harnesses for cars with post-type alternators are constructed using a 4 gauge, fine-strand (1672 strands) cable with thick, high temperature insulation. Harnesses for cars with blade-type alternators feature OEM connectors and two 8 gauge, fine-stranded cables (1330 strands), also with thick, high temperature insulation.
Both harness styles are terminated with gold plated HD terminals. The exciter wires are VW color coded and use OEM connectors.
All Harnesses come complete with assembled alternator wire, exciter wires (where applicable), high temperature nylon loom, and instructions.
Description Part Number Price
Rabbit, Jetta 1, Scirocco to 1/'84, Cabriolet through 1/'84 10.903.200 $29.95
Golf 2 models, both 8V and 16V, '85-'92 10.903.201 $19.95
Jetta 2 8V and 16V '85-'92, Scirocco 1/'84-'88,
Cabriolet 1/'84-'93 10.903.202 $19.95
Corrado G60 10.903.203 $19.95
Golf 3/Jetta 3, Passat B4 '95-'97 10.903.201 $19.95
Fox 10.903.204
