1 - 4 of 4 Posts
I need instructions on how to change my battery myself.... very detailed safe non-electrocution type instructions..'95 MK3 Jetta 2.0L
dekuji.
ashley marie
Re: Battery Change Instructions Please (eurotrashley)
turn the car off, n then your good to go ?? if your really scared for you life wear very thick rubber gloves
Re: Battery Change Instructions Please (Jetta2NR)
Car off
Disconnect - cable
Disconnect + cable
Unbolt the bolt on the drivers side of the bottom of the battery to release the bracket holding the battery in position.
Remove battery
Put in New battery
Tighten bolt to hold battery in position
Clean battery Cables with a wire brush
Connect + cable
Connect - cable
Turn off alarm with key in drivers door lock
Turn ignition on for 2 mins
Start car and let idle for 2 mins (do not touch the gas)
1 - 4 of 4 Posts
