Battery Drain
During the last 3 months the battery has been drained dead 4 times for no apparent reason. The frequency has been random. I drive the car daily 100 miles per. No lights have been left on, I have also checked the trunk and glove box switches etc....
- After the first dead battery I changed in a new one.
- After the 2nd dead. I reset all DTC's and run a scan; the one below was the same.
- I checked the alternator for any AC voltage, nothing really to note. I then also checked to see if the car was going into sleep mode, no apparent issues. The current draw (all doors etc closed and alarm armed) was ~ 2.5 A for 5-10 minutes and then was ~32mA after. I have checked this 8 times since with the same result and the battery has not been dead the next time I start the car.
- The car is stock and I have owned it since new, 2005.5 TDI. I have activated the windows up/down with remote.
- Measuring Block 130, 131 and 132 data from Address 19 - CAN Gateway all show "1"
- I ran all the output tests for each comfort module, no problems
- On occasion I have had an error for the rear right locking module, see below, but currently not an issue. Also I have removed the B pillar plug for this door to inspect the wires; none are broken.
The 00470 error is new to me....
- Where should I start looking?
- Am I looking for a broken wire or is a bad module causing this error.
- How can I determine which Bus line is down?
Many thanks for any help.
Paul (Pmmgti at aol dot com)
Tuesday,12,October,2010,18:40:37:63223
VCDS Version: Release 10.6.1
Data version: 20100831
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 72
7D
VIN: 3VWST71K45M639072 Mileage: 244260km/151776miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H01--- Serial number: VWZ7Z0E2140832
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64CDDBACDE29
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 H HW: 02E 927 770 AD
Component: GSG DSG 041 0905
Revision: 04004010 Serial number: 00000501290386
Coding: 0000020
VCID: 1835BF5C52E1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
VCID: 3A7145D40C2D
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CDDB38C36F9
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000075683
Coding: F4098E02400418000014000000140000002077035C
VCID: 2F676480C76F
Part No: 1K1 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Part No: 1K0 955 559 M
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
Address 0F: Digital Radio Labels: None
Part No SW: 1K5 035 553 K HW: 1K5 035 553 K
Component: SDAR XM H04 0160
Revision: 00000000 Serial number: VWZ4Z7G0060920
VCID: 316362F8D15B
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD01W16/
Coding: 0012627
VCID: 2E597984C065
Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AB HW: 1K0 953 549 AB
Component: J0527 010 0045
Coding: 0010041
VCID: 72E1ADF414DD
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 971 D
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0023203
VCID: 2C5D738CF679
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 2900105324003E
Coding: 3F3F0B620F1002
VCID: 29538A98F98B
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 34
Mileage: 244268 km
Time Indication: 0
Date: 2000.00.00
Time: 00:38:12
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TP2EZ03
VCID: F8F51FDCF2A1
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3HL 2120
VCID: 2C5D738CF679
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001271
VCID: 366951E43835
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.3 1502
VCID: 306567FCDA51
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106281B0906050FA0080F0490A540
VCID: 82017D34A47D
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 34
Mileage: 244269 km
Time Indication: 0
Date: 2000.00.00
Time: 00:42:50
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1K6 035 456
Component: 08K Audioverst. 0003
Revision: 00002000 Serial number: 00000000023082
VCID: E9D34A98B90B
1 Fault Found:
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001271
VCID: 37775CE03F3F
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 HW: 1K0 035 180
Component: Radio DE2 008 0115
Revision: 00008000 Serial number: VWZ4Z7E2021166
Coding: 0010010
VCID: DDBB6E487D43
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 316362F8D15B
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 32616DF4D45D
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5B7E88CD63
End ---------------------------------------------------------------------
Tuesday,12,October,2010,18:42:25:63223
18:42:02
1-Wire CAN-Comfort Status
Cent. Elect. 1 Central Electronics (J519)
Central 1 Comfort System (J393)
Dr.Door 1-W Door Electronics Driver (J386)
Pas. Door 1 Door Electronics Passenger (J387)
RL Door 1 Door Electronics Rear Left (J388)
RR Door 1 Door Electronics Rear Right (J389)
St. Wheel 1 Steering Wheel Electronics (J527)
HVAC 1 Heating/Air Condition (J255)
Aux. Htg 1 Auxiliary Heating (J604)
Chassis Type: 1K0
7D
Coding: 0050078
VCID: 64CDDBACDE29
Coding: 0000020
VCID: 1835BF5C52E1
Coding: 0021122
VCID: 3A7145D40C2D
VCID: 6CDDB38C36F9
VCID: 2F676480C76F
Coding: 00065493
Shop #: WSC 00000
Coding: 00217125
Shop #: WSC 00000
VCID: 316362F8D15B
Coding: 0012627
VCID: 2E597984C065
Coding: 0010041
VCID: 72E1ADF414DD
Coding: 0023203
VCID: 2C5D738CF679
VCID: 29538A98F98B
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 34
Mileage: 244268 km
Time Indication: 0
Date: 2000.00.00
Time: 00:38:12
VCID: F8F51FDCF2A1
VCID: 2C5D738CF679
Coding: 0001271
VCID: 366951E43835
VCID: 306567FCDA51
VCID: 82017D34A47D
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 34
Mileage: 244269 km
Time Indication: 0
Date: 2000.00.00
Time: 00:42:50
VCID: E9D34A98B90B
1 Fault Found:
011 - Open Circuit
Coding: 0001271
VCID: 37775CE03F3F
Coding: 0010010
VCID: DDBB6E487D43
Coding: 0000144
VCID: 316362F8D15B
Coding: 0000144
VCID: 32616DF4D45D
VCID: 2D5B7E88CD63
18:42:02
