Re: Battery, Grounds, etc......Mk1 (DrewL)
Quote, originally posted by DrewL » |
I have a few questions and am not much of a whiz when it comes to anything electrical so here it goes. Besides weight, what are the pros and cons of a Braile (sp?) battery? Which size battery would be needed (CCA, etc)? Are there any places to buy beefy battery cables and /or grounding kits for my Scirocco? Any nudges, pushes, or swift kicks in the right direction are very much appreciated. |
We ought to page Scott Williams to the thread shouldn't we?
In my very limited opinion the Braille battery will probably work fine in a racing and autocross application and you should be able to get by with as little as 400 cca as your basis. There are tons of batteries in that range that are about as compact and probably a tad bit more powerful when you start to explore the idea of looking at other applications such as high-torque high compression motorcycle batteries but the Braille is about the lightest battery you can get away with.
As far as a remote battery kit to relocate the battery to the hatch area there are several generic kits available through speed shops that can accomplish this. I am actually going to be going down this same road in a couple of weeks and thought about exploring the idea of getting the battery cable out of a late model BMW (my wife's X5 as an example) because the cable has a terminal that resides in the engine compartment that would allow you to jump the battery from the engine compartment. If you think about where most of your accessories like lighting, gauges, and stereo stuff terminates it is mostly on the driver's inside fenderwell just shy of the battery so you could probably create some sort of power distribution block off of the termination point so that you could run your headlights and accessories without too much trouble.
I would also suggest that you invest in a battery box; as a late teenager I was the victim of an exploding car battery and I would never wish that experience upon anyone and having the battery aft of the firewall is a dicey proposition.
