1 - 4 of 4 Posts
Have you looked at 034's fuel rail?
Yup. Can get this bbm from a private person, so I might give it a go. And I asume you can place the in/out fittings in both ends of the rail. But was curious about the setup they choose to sell by having all fittings and fpr on one side. Seen Schimmel SRIs with the same fpr/fitting setup.
Discussion Starter · #4 ·
Have been running this rail for awhile now. The oem clips that holds the injector in the roght place doesnt fit. Injector mount on the rail is WAY to wide. Is the meaning that I should not ise any clips? Just slide the injectors in the rail and tight the rail, hoping for the injectors to stay safe in the rail?
1 - 4 of 4 Posts
