1 - 19 of 19 Posts
Is it any problem to but BBS Challenge 19" et:30 with 235/35-19 tires on a Golf GTI -00???
There are some people that told me it woulden´t fit..
Please if you now, tell me!!!
Re: BBS Ch 19"/ problem?? (Holmgren)
it will fit fine...but if you dropped your car, you might wanna get different size of tires....but like i said, depends on how much you dropped your car.
Discussion Starter · #4 ·
Re: BBS Ch 19"/ problem?? (Kei78)
If I drop as mutch as the Jetta on the pictures have, whould it fit???
The tire size is fine as well...you might rub if your dropped that low...every suspension setup varies, so the only thing you can do is try...if you have coils it makes it easier...
They will fit! I have 19" CH's with 235/35-19 Toyo FZ4's, and a 2 inch drop. There is no rubbing at all, even hard cornering. Here is a pic!
Quote, originally posted by Holmgren »
Yeah this is my car. The offset is actually 32 but the fit fine and I have a 40mm drop and no rubbing. I could even go a bit lower with out rubbing I think.
Re: BBS Ch 19"/ problem?? (RavinJetta)
Quote, originally posted by RavinJetta »
The offset on the CH's 19x8.5 in 5x100 is 30mm not 32mm. Check the inside of one of the spokes, it will show you there. Here is a pic for proof!
Discussion Starter · #10 ·
Re: BBS Ch 19"/ problem?? (AUDIPWRD)
I have send a mail to BBS and they told me that they dont have any BBS Challenge 19" 5/100 with et 32.. Only et:30..
Also, there was a thread a couple of days ago with a Imola 20th with 19" CH's. Here is the thread!
http://forums.vwvortex.com/zerothread?id=1233334
Quote, originally posted by AUDIPWRD »
That thread looks familiar!!
I only have rubbing when the wheel is held at full turn (mostly when backing up), if I let it go just a little bit the rubbing stops. It is nothing bad just a little bit, I have not rubbing when actively driving.
http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif to who evers car that is in the first picture.
Oops then nevermind then
Re: BBS Ch 19"/ problem?? (KoZmiK)
Its fine, just really depends on how much your dropped... my car is dumped in the front and i rub occasionally... i have 19" ch's... i just recently changed my tire size to 225/35zr 19 fz4 toyo's to get the stretched look... and i love it... best of all it doesnt rub, well at least yet untill i get some spacers to pop them out! LOL... ill post up pix as soon as i take some... its dirty as hell right now... so maybe later on this weekend..
Discussion Starter · #17 ·
Re: BBS Ch 19"/ problem?? (johngraphix)
RavinJetta:
So you have et:30, or????
johngraphix:
I look forwad to see your car.
RavinJetta:
johngraphix:
30 My bad
1 - 19 of 19 Posts
