1 - 6 of 6 Posts
I want to have the lips of the wheels flush with the fenders. It seems like i would need the lips to be 1" wider in the front and 2" wider in the rear, but i'm not sure how the sizing is set up. If i ask for the 1" lips will i get the same size as the lips from the factory or will i get lips that are 1" wider than factory? ohh and if ur running htem please tell me what size ur running.
Re: (cabrio_driver)
Well i don't think rubbing will be that much of a problem as i can adjust the suspension to the point where it won't rub, and will bring it back down to earth when i'm just cruizing. I love coilovers http://****************.com/smile/emthup.gif do you have the answer to my question though?
no sorry I don't have an answer, I'd like to know this too thou as RMs are probably my next purchase. i have 15x6 inch RAs and had rubbing problems so I thought I'd let you know. I love my coilovers too but I like the low look all the time so I had to trim.
Re: (cabrio_driver)
where r u rubbing on your 15x6 RAs? inside or outside? depending of the wheels ofset and width i've seen them rub in both places, but with RMs i have absolutly no problems with my car dropped to where it is right now, and if i had swaybars the rubbing problem would be less so. I can handle having to drive slowly around turns when on public roads, i'll just have to rais the car a little when i autocross.
1 - 6 of 6 Posts
