1 - 8 of 8 Posts
Disclaimer: Any person who decides to perform this modification, does so at
their own risk. I shall not be liable for any kind of damage, whether direct or indirect,
resulting from use of the information provided in this post.... Just don't do it !
First of all, I will like to thanks to those individuals who previously posted DYI threads on how to
completely conceal a radar detector + Auto Dim rear view mirror installation.
dsumike - 2012 GLI + Gentex Auto-Dimming Mirror
ExhaustNotedsumike -DIY Bel STI-R Plus/Escort 9500ci install w/integrated rear view mirror display
sor -V1 (rearview mirror) concealed install part 1 - remote display
BELTRONICS STiR Plus Installation + Auto Dim rear view mirror / display
Gentex GENK41A Auto-Dimming Mirror with Homelink
Bel STI-R Plus
Audi A4 USED Auto Dim Rear View Mirror Housing
First... the Gentex GENK41A base SUCKS. I was going to get the VW adapter.. but for $25 I end
up buying a used AUDI A4 rear view mirror that has wire cover and.. is compatible with the Jetta
rear view mirror base.
All I had to do was to figure how to put everything together:
I cut the used mirror base to make new base for the Gentex mirror:
I disassemble the STI R Display module, and glued to the plastic back plate with ... J.B.Weld, also I drilled a small hole and installed the bi-color LED to the front cover.
Make sure to sand down the plastic before using J.B Weld to glue plastic parts!
Note: To open mirror, You may want to get some iPad / iPod opening tools:
iPad Opening Tool for iPad Repair
10 Pry Tools Repair Open apple ipod/ iphone
More to come when I figure what to do with the control module.
Discussion Starter · #2 · (Edited)
GPS Antena location: Under the rear deck.
Radar / Laser receiver location: Behind the grill next to the VW logo ( I had to cut a section of the grill to install the receiver )
Discussion Starter · #4 · (Edited)
Is still expensive, I always wanted to get one.... and then some dude put one on e-bay for $900.00.
They sell for around $1200 from authorized dealers, sometimes You can get them cheaper at eBay, it took me some time to find a good offer.
Discussion Starter · #7 · (Edited)
Update: Control Module installation:
I took the complete compartment behind the shift lever out of the car.
1) Remove shift lever cover by lifting carefully from the back.
2) Remove 2 screws.
3) Disconnect Aux + Lighter socket connectors.
I took the Control Module apart, both plastic half are glued to each other. I removed the "sticky"
tape from the back of the module, drilled the necessary holes and used screws and a small
amount of J.B.Weld to secure the bottom half in place.
I also had to cut the wires.
After, I re-glue both plastic halfs with small amounts of J.B.Weld, and solder/insulated the wires.
This is how it looks after everything is connected.
1 - 8 of 8 Posts
