Belts
578 Views 4 Replies 5 Participants Last post by  spitpilot
1. Does anyone know after how many miles or years you are supposed to replace the timing belt?
2. Does the engine run with valve interference?
1 - 5 of 5 Posts
Re: Belts (scobond)
1. 4-years or 60,000 miles
2. Officially no, not interference on a stock engine. Though people have bent valves when their TB broke so it isn't something you really want to chance.
Take top belt cover off and inspect the belt
Re: (JR Martinez)
I changed my serp. and timing belt and STILL get the hissing sound,(in damp/wet weather only)it goes away with a little spray of STP belt dressing.I didn't change the tensioner pulley and was thinking that it might be the culprit,is there a seperate power steering belt??
Re: (vw valance)
Yes there is a little standard V belt that drives power steering belt. You change the serp belt tension pulley???? It might be causing noise.
1 - 5 of 5 Posts
