Re: best audi or dub engine I can fit into my jetta IV (vivagarcia)
HPA Motorsports makes a VR6 twin turbo setup using the the Audi S4 engine components installed on a VR6. They can squeeze that engine into a beetle and have installed it in a golf so I'm pretty sure it would fit in your Jetta.
Specs:
Type...........Euro 24v, 15 degree V6, cast iron block with aluminum head
Bore x Stroke....................... 81.0 x 90.2 mm
Displacement..................................2792 CC
Compression Ratio...............................7.0:1
Valve Gear.............Chain driven dual overhead
cams, 4 valves per cylinder,
hydraulic lifters
Exhaust System......HPA Racing 3.0" T-304
Engine-control.................HPA/HGP ECU
Max Horsepower....508 bhp @ 5600 rpm
Max Torque............556 lb-ft @3400 rpm
Redline..........................................7200 rpm
Recommended fuel...........92 octane or higher
Turbo System
Twin KKK K-04Turbochargers
(1.4 Bar or 20 psi)
Cast Aluminum Intake Manifold
Twin Intercoolers
http://www.hpamotorsports.com
