Re: best cams for 40mm carbs? (onelow2dr)
At least get the Techtonics cams. If you want a bit more go for the Schrick 268. With 40mm carbs on a 2.0 you don't want too much cam or you will run out of air on the top end. Use 36mm chokes (biggest for a 40).
