Hey all, what do you think is the perfect offset for a 19x9.5" wheel for a TTRS [assume 255/35-19 tire] with the goals (in order of priority):
1) no rubbing
2) great handling / steering feel
3) looks / stance
Stock is 19x9" +52mm.
I know some folks have had success running VMR 19x9.5" et45 wheels, so I'm tempted to go with what works. BUT that is still a good +7mm of offset, plus 0.25" of rim extension per side of the wheel (~6mm each), so the rim outside edge will stick out about 0.5" further than stock, while the tire tread will only be ~0.25" further out than stock (due to just the offset shift, since the tire size is the same and centered on the wheel).
For this particular wheel, I can choose a custom offset. Given that, would you go with et45? Or would et48 be better fitment-wise (some would say slightly worse looks-wise)?
Any opinions welcome! Thanks.
1) no rubbing
3) looks / stance
