1 - 15 of 15 Posts
I had cobalt bits in the past that went through a wheel stud like butter. But now, i have a broken extractor stuck in a broken bolt and the broken extractor has chewed my bit to pieces.
Are there any super strong bits that i could use?
I’m not a loser. I’m a winnah!!
Re: Best drill bits for drilling out broken bolts? (breakfasteatre)
yo dawg I heard you like broken.......
no serioulsy though, time for the oxy torch. extractors are hardened tool steel, right? that should wreck most off the shelf drill bits.
Re: Best drill bits for drilling out broken bolts? (patrikman)
Picture?
If you have any nub of the extractor, file down 2 opposing sides, so you can get a vice grip on it, then turn it out.
Or, if it's in deep, you could maybe use a punch and hammer to put a straight slot in it, to work it out backwards.
Discussion Starter · #4 ·
a stub didnt even break off, shining a flashlight into the hole looks like it broke off even with the broken off bolt i had drilled into.
Re: FV-QR (czook)
Anyway you can use a punch to try and break apart the extractor and get the pieces out?
I have never had good luck with extractors; I have done exactly what you did. I don't use them any more. I curse the person who came up with the name E-Z Out.
I now center punch as close to the center of the broken bolt as I can, then I try to drill out the bolt by using a left handed drill bit. If you get lucky, the action of the bit will eventually back out the bolt, but if not at least you can just drill it out anyway.
Discussion Starter · #7 ·
the stupid thing is, and i am really mad at myself for doing this is that i tried the extractor one last time before i went to drill out the bolt, and when i went to remove the extractor because it wasnt working, i broke the bolt. I didnt break it trying to extract the broken bolt, i broke it trying to pull the extractor out of the pilot hole. ****ing cluster **** bull****
Re: FV-QR (randyvr6)
Quote, originally posted by randyvr6 »
If I ever meet the sadistic bastard that named it "E-Z Out", God help me...
Re: FV-QR (ReflexJettaVR6)
snap-on thunder bits are the best i've used. good luck drilling through an extractor, there pretty damn hard.
Might be easier to judge with a picture.
I've (slowly) gotten bolts out using a punch and just tapping it with a hammer in the counter clowckwise direction. Position the punch on an edge, punch it straight down into the metal to make a depression so when you come in from the angle it will have something to bite into - then delicately keep working at the bolt the bolt. But that does no good if the bolt is seized, is it?
Discussion Starter · #11 ·
yeah the problem is that the broken off part is about 2 inches into the lower control arm bushing steel sleeve. I think im going to put everything back together, limp it down the street and see what my options are at the machine shops and the local vw shop.
thanks for the suggestions guys
Re: (breakfasteatre)
You wont find a drill bit that is going to chew through carbide tools.
A torch is going to be your best bet, I have had to do the same thing at work a few times. Fortunately for me, work has all those nice tools.
One thing you could try if you wanted is an air or electric powered engraving tool. They vibrate enough to shake threads loose, sometimes. Might be worth a shot at renting one.
Re: (TurboWraith)
You can drill tiny pilot holes all around the extractor and then twist and pull it out, the best way i have found, you will not find a drill bit that will penetrate the extractor (dont waste your time).
Banned
Re: (TurboWraith)
Quote, originally posted by TurboWraith »
You might be able to shatter it too. I've used dry ice on bigger carbide stuff and hit it with a punch/hammer and got it to shatter before.
1 - 15 of 15 Posts
