By just replacing oil you are leaving deposits in the engine and by time this will cause a sludge. Carbon and sludge get between the piston rings and frame the rings from freely movement that means the compression starts to dropping down vehicle gas millage will drop down and the oil circulation pressure will drop down because of the deposits start building up in the oil system, and also can cause engine noises in cold start as lifter noise.
Now I understand there is technicians are concerned about some engine flushing products that can cause damage because it does not lubricate when the product in the system and that can harm the bearings & can break loose sludge which can clog filter, most of these engine flush products in the market designed from alcohol, which alcohol is not a lubricant.
Today with the latest technology formula from MotorPower Care these issues are solved, and can save major big engine repairs. This latest formula does not contain alcohol it’s designed from carbon minerals, and lubricates 93% when its running in the engine and will dissolve sludge, varnish & deposits. This product certified by TUV in Germany OEM approved.
You can test results by yourself, first take a compression test on your vehicle, second pour the product to the old oil that you have in the engine let it run for 20 to 30min then change oil with filter then take compression again and you can compare numbers & see improvement. Or another easy way check your gas millage before and after the cleaning. Highly recommended to be used with every other oil change to keep system clean.
https://ibb.co/nsK6N6z
https://youtu.be/70B9M535mCg
