Re: Best motor oil for a 1.8T? (G19)
Quote, originally posted by G19 » |
What's the best motor oil for the 1.8T? I've used Mobil 1 Synthetic for a long time in my other cars, but my car only has 2000 miles on it. I'm going to change it at 3000. I don't think I'll convert to synthetic 'till I hit 5,000-10,000 and I have it chipped.
So, what's a good motor oil that's been known to work well w/ the 1.8T? |
my advice is to switch to synthetic at your next oil change. your engine will thank you by lasting 300,000 miles
as for which sythetics to use.... Castrol Syntec is a semi-synthetic (group 3) they'll sell you at the dealership for $10 a quart... if you're not going to use Pentosin or Volksynthese 5w40 you may as well use Shell Rotellla T 5-40, its a group 3 like Syntec but costs $12 a gallon at Target or Wal-Mart its what I am using right now because I didnt want to pay $65 for a dealer oil change again
Rotella T is aimed at diesel motors but also meets the VW recommended API SJ and SL specs for gasoline engines, decent stuff but once my supply runs out I'll be switching to a fully synthetic oil from Pentosin or Volksynthese
Pentosin and Volksynthese are German fully synthetic (group 4) oils that meet the specific VW oil (502.something) specs for the 1.8T
you can get 5L (~5Q) of Pentosin for $28 @ ecstuning.com and Volksynthese can be found online for about $25 a gallon as well
Since Mobil-1 doesn't produce a 5w40 I dont recommend Mobil-1 for the 1.8T
Modified by ShockWaveVT at 5:07 AM 1-9-2004
