1 - 7 of 7 Posts
I'm going to be installing a sub and amp onto my Monsoon system tomorrow. I checked the FAQ and saw where that one guy had run his power wire. But after reading other responses people seemed to have some better ways of doing it. Any more suggestions would be great. If you have an actual picture that would be even better. Would like to keep the install as clean as possible.
I have a 2002 Jetta, AVH Engine. I want to keep all of the stock monsoon parts with my Phatbox and just add an Amp and Subs. (If that helps)
the DIY that has the power wire going through a grommet in the firewall is perfect IMO on the inside of the car the wire pokes through a few inches above the dead petal and from the u can just run the wire down the driver's side of the car
Re: (jwill'sMK4)
Yeah just go through the firewall and run the wire undernieth the door sills to your trunk. will take a bit of work to get the wire completely hidden, some of the interior parts are quite... stubborn.
Another thing, if you run RCA cables, make sure they are on the opposite side of the car as your power wire, your you might get engine noise.
1 - 7 of 7 Posts
