Especially when they see no big benefit from the unlimited runtime of corded models. Those machines have become an even better investment thanks to continued improvements from manufacturers. Here is a quick rundown of the best stick vacuums right now.
1. Dyson V8 Absolute
From one of the best vacuum cleaner brands, this premium cordless stick is just as impressive as its predecessors in the V series. It's a lightweight vacuum that can be used as a handheld unit to expand its cleaning capabilities. The Dyson V8 is highly maneuverable, powerful, and easy to use.
The new dirt emptying system is the absolute proof of how Dyson wants to make this stick as convenient as possible. It makes the removal of debris and dust from the canister almost hands-free, meaning you don't need to get your hands dirty after vacuuming. This system is among the most interesting features you can find in all stick vacuums.
The V8 has two specialized cleaning heads: one for hard floors and one for carpets. Additionally, Dyson provides three attachments: a mini motorized tool, a crevice tool, and a combination tool. The filtration system is equipped with a HEPA filter, which is a clear improvement over its predecessor, the V6.
2. Eureka RapidClean Pro
If the Dyson V8 is too expensive for your budget, even if you really like the design, have a look at the Eureka RapidClean Pro. It's a lightweight stick vacuum that can transform into a handheld unit, and all of them come with a much more affordable price tag.
The RapidClean Pro works great on both low-pile carpets and bare floors. You can easily move it around between surfaces and empty the dust after you're done with the vacuuming. But you have to keep in mind some small issues many users have faced - a common issue of affordable products. The brushroll of the RapidClean Pro gathers a lot of hair, so you have to manually remove it often. The build quality of this machine can also be better.
3. Hoover Impulse
The iconic cordless stick vacuum design of Dyson has inspired many manufacturers to make similar models in the hope of chipping away the British brand's market share. The Impulse is such an attempt from Hoover. Like Dyson, Hoover wants to capitalize on the growing demand for lightweight, versatile, powerful, and easy-to-use vacuum.
The Hoover Impulse can produce plenty of suction despite its small weight, and like the V8, you can use it as a handheld vacuum as well. The machine has two power settings, user-friendly controls, and three attachments. However, compared to other best rated vacuum cleaners, the Impulse is slightly louder during operation. This is something you must give some thought to before buying.
4. Shark APEX
As one of the best vacuum cleaners in the world, the Shark APEX has a small difference in design, making it a really interesting machine. It possesses elements of both stick and upright vacuums. Users of the APEX benefit from the best of both worlds: the convenient grab-and-go design of traditional sticks and powerful, advanced features that we usually only find on high-end uprights.
This machine is equipped with the Lift-Away design (a favorite of most Shark users), Zero-M and DuoClean technologies, LED lights, and a sealed filtration system with a HEPA filter. The retractable wheels of the APEX can even pop out automatically when the machine is in the upright position, enabling the unit to stand on its own.
5. Shark IONFlex
What is the best vacuum cleaner if you prefer a cordless stick over an upright from Shark? The IONFlex is your best bet. It's among the top 10 vacuum cleaners of this brand that has two batteries and two brushrolls. You can also bend the flexible wand to a full 180 degrees. The Shark IONFlex has strong suction, allowing it to pick up debris and dust from all kinds of surfaces. However, the vacuum is quite bulky for a stick, even in its handheld mode. The bendable wand using the MultiFLEX technology also doesn't live up to our expectations.
6. Shark Rocket PowerHead
The Rocket PowerHead is another answer from Shark to the Dyson V8, and instead of competing directly with a traditional stick vacuum, Shark has chosen a hybrid approach. Like the APEX, the Rocket series consists of a lightweight vacuum with a low profile, swivel steering, and a self-cleaning brushroll. Users can also convert them into more portable units at the push of a button.
7. Dyson V11
The V11 is the newest version of Dyson's V series and also one of the best vacuum cleaners on the market. With this powerful machine, Dyson has proved it can close the gap in performance between full-size, corded canisters/upright and cordless sticks.
In its highest power mode, the Dyson V11 can deliver a suction as powerful as many upright vacuums. On top of that, this cordless model is much more easy-to-use than corded vacuums. The main compromise is the runtime, which is less than half an hour in the Boost mode.
8. Shark Vertex
What is the best-rated vacuum cleaner if you want the highest-end stick vacuum from Shark? As one of shark’s premier models, the Vertex cordless stick has all the bells and whistles. Shark equips it with two brushrolls, one of which has the self-cleaning ability, a flexible wand, a detachable battery, LED headlights, and a sealed filtration system with a HEPA filter.
After running the Shark Vertex through its paces, we have been impressed by its ability to pick up debris and dust from both bare floors and carpets. The self-cleaning brushroll also reduces the amount of hair tangled around it. By simply detaching the wand, you can also use the Shark Vertex as a handheld unit. However, this Shark cordless stick vacuum is still pretty hefty compared to the Dyson V8.
Conclusion
Like what we have seen, the Dyson V8 is not the only cordless stick that’s worth your money. There are plenty of alternatives you can consider before getting the right vacuum for yourself.
The recommendations in the best vacuum cleaner reviews above are possible thanks to the deep expertise of our reviewers and writers, who have spent much time trying those vacuums firsthand. The goal of TheKingLive is to provide our readers with the most practical information so they can make informed decisions. This includes all kinds of household appliances, from vacuums and coffee makers to baby monitors and pressure cookers.
3. Hoover Impulse
4. Shark APEX
5. Shark IONFlex
7. Dyson V11
8. Shark Vertex
Conclusion
