1 - 4 of 4 Posts
i have yellow koni adjustables, i would like the ride to be more performance orientated but i dont want to loose every day driveability. i have a gti vr6 so how stiff should it be int he back and front?
if there like my konis (on my rx7) they dont have any set positions.. but i have mine set up as 3 turns off the top(going from stiffest reduce it by 3 turns) and as stiff as it gets for the rear... keep in mind its a RWD car.
i would just say to keep it so you dont rattle your teeth out just set it on med. all the way around. there still going to be way stiffer then stock.. and if your running aftermarket springs they will be stiffer then stock.
Re: best setting for koni adjustables?? (RoninGTI)
I live in Joisey too, so we prob drive the same kinda roads. On my WE Jetta, I have the fronts 1 full turn stiffer,backs 1/2 turn stiffer. I wudnt go much stiffer on backs, but you can play with the fronts as they're so easy to adjust. I just went 1/4 turn at a time. But I like my ride kinda stiff
1 - 4 of 4 Posts
