1 - 4 of 4 Posts
i was gonna buy some meguirs nxt generation , will that do the trick or is there special stuff i need to do the job?thankz
Re: best way to get rid of swirls? (GtiVR6racer)
use meguiars #7 if doing it by hand to remove swirls then seal it with #26. if using a buffer use #3 then #9 and then seal it with 26. keep up with the protection by using #34 after every wash.(spray on wax/protection) you can do the 7, 26 every couple months or if your anal once a month to keep it really clean.
1 - 4 of 4 Posts
