ok
my door is rusty
but its surface rust...
but the surface rust has made some dimples here and there...
and regular arm power and emery cloth isnt smoothing it out enough...
I want to grind it down SMOOTH.
would it be a bad idea to get an angle grinder and use that to grind off the rust?
So we're talking a larger area of rust then? If you use something hard (like a grinding stone) you risk going through the metal. Sounds like you really want to go out and get that angle grinder doncha?
Chapel, if it is at the bottome of the door, you might as well go find another door. That rust no matter how much you remove will always come back... that is if it is a daily driver. I had mine all nice and painted and the door ended up rusting again there. Same with a rear hatch.. rust will always come back there too. sorry to say
Just warning you ahead of time.
i think you can buy the wire brush things in a type that will mount in a normal drill.... i think they are really cheap too...
i see them all the time at my local hardware store....
the wire brush will knock down the rust, but if you get an actual grinding disk it will take the rust off and give you the bare metal of your door, which is what you want. Once you have done that the grinded metal will be a bit lower than the rest of the panel and thats where the bondo or finishing putty comes in. After that you need to prime, sand and paint. Primer is not waterproof so even if you prime it and dont paint the door the rust will eventually come back, you can always keep repeting this but your best bet is to get it painted after. It shouldnt rust after that.
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
