It’s been our experience that finding a reliable clutch manufacturer is not always the easiest thing to do. Having a kit be “hit or miss” is not ideal for us as a retailer, nor is it something that we want for our customers. In light of this, we have sought out what in our opinion is a supplier who is able to meet our needs and offer us exactly what we, and ultimately our market wants in a clutch kit – reliability, performance, and value. Competition Clutch was able to provide us with specifically what we asked for.
The materials used are tried and true, with a no frills approach. Competition Clutch does not use gimmicks, and they are already a well established name in the import performance industry. With lines and worlds blurring together, and expansion into the European side of things was a natural progression, and one we are looking forward to further cultivating.
The Stage 1 Kit assembly provides an estimated 225-lbs/ft holding capacity and is properly suited for street use. The stock organic clutch disc is matched to a performance pressure plate that will provide smooth engagement and extended life.
The Stage 2 Kit assembly provides an estimated 300-lbs/ft holding capacity and is properly suited for aggressive street use and moderate track use. The organic disc is matched to a performance pressure plate will provide smooth engagement and extended life.
The Stage 3 Kit assembly includes a segmented ceramic material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly provides an estimated 400-lbs/ft holding capacity.
The Stage 4 Kit assembly includes a 6-puck clutch disc with a performance pressure plate. This assembly provides an estimated 500-lbs/ft holding capacity and is properly suited for big turbo and strip applications.
The Stage 5 Kit assembly includes a 4-puck clutch disc with a performance pressure plate. This assembly provides an estimated 525-lbs/ft holding capacity and is properly suited for big turbo and strip applications.
Kits Include:
- Performance pressure plate
- Performance clutch disc
- Lightweight 18.4lbs forged steel flywheel
- All applicable bearings
- Appropriate alignment tool
- All hardware required for installation
- These clutch kits fit 2.5L Inline-5 engines with 5-speed manual transmissions only. Does not fit 02M 6-speed equipped vehicles!
