1 - 20 of 27 Posts
Today I was driving in town...then my car just turned off and I thought I heard metal clanging...kinda like some teeth came loose somewhere in some gear. When I try to start my car now...the starter just spins hella fast and nothing happens(my RPM hits about 3-400 or so while the starter is whining), no fire...the motor doesn't turn at all..just a spinning starter and a tach showing 3-400RPM. Also there's a slight rocking motion about 1/10th of how the car rocks when it's starting for real. I checked my belts and they're there.
What could have happened to my car?
Thanks. Would that explain why my car just shut off out of the blue though?
I have an Aamco tranny that's still under warranty (2nd gear grinds like mother sometimes and I already have an appointment). So I hope it's a tranny problem (bet you've never said that before).
2001 AWD New Beetle, 2013 Audi S5
Re: Big, Big Problems (themachasy)
I would bet something else since you're getting rpm signal that means the crank is turning. Try marking the crank pully with a pen or whiteout or something, try to start and see if it has moved. You might have sheared teeth off the timing belt.
That was one of the first things I did. I actually just put a dab of spit on the belt...didn't move. Like I said...the starter goes...the belts don't....no spark or anything. All you can hear is the starter going.
Discussion Starter · #6 ·
Yeah just had my dad turn the key while I watched...definitly timing belt. I looks like it's trying to go but moves about 1cm and can hear what can only be described as a peice of rubber flapping against a metal gear. Stupid timing belt.
Re: (Buschwick)
Quote, originally posted by Buschwick »
yea def sounded like a t-belt issue from the start...hope for you your valves didnt have a party with your pistons...cuz that means $$$$ http://****************.com/smile/emthdown.gif
Re: (Golfmk3_18)
i had the same type deal one of the t belt pulleys wore so it couldnt grip the t belt rendering it not able to move i had to rebuild the head get it milled i was kinda lucky in a way i only bent cyl 1 and 4 valves but my car wasnt runnin then cut out i shut it off and it just didnt start up bent the valves from cranking it actually good luck dont get jerked when u get the head rebuilt
Discussion Starter · #9 ·
not getting rebuilt..
I'm getting a fuggin horse...when it dies I'll ride its offspring...and so on
Discussion Starter · #11 ·
over $1800 plus tax,..ended up with 8 trashed exhaust valves for anyone who was wondering how much it deflated my wallet.
TAKE CARE OF YOUR TIMING BELTS PEOPLE!
Discussion Starter · #13 ·
105k....
I bought the car when it had 88k about a year and a half ago...if the guy had taken care of it like he should have I would not be in this position, that belt should have been changed long before I even bought the car. Buyers beware I guess.
Since my $6500 cash purchace I've bought a shiny new Aamco transmission, replaced a whole set of ignition coild by now, replaced the PCV system, and now bought a rebuilt head (mine).
Nothing but a peice of garbage if you ask me being about $13k into an 8 year old car with 88k.
Modified by Buschwick at 7:44 PM 9-19-2008
Discussion Starter · #14 ·
OH and a new OEM DV, a y fitting in the cooling system that was tricky to find...things just always break on me....always.
Re: (Buschwick)
well you did put 17k miles on it so you could have changed it out before then and saved yourself quite a bit of money
why did you have to change the tranny?
the coils are to be expected on these cars its about like changing the plugs haha
Re: Big, Big Problems (Buschwick)
Noooooooo!
sounds like the timing belt broke. Comp test her and see. It will spin pretty dam free with 8 bend valve letting all the air out.
Discussion Starter · #18 ·
That's the point...with 88k it should have damn been done already.
And about 3 months after I bought it my LSD exploded through the tranny case...needed a whole new transmission.
Discussion Starter · #19 ·
Re: Big, Big Problems (velocity196)
Quote »
Noooooooo! sounds like the timing belt broke. Comp test her and see.
Thank you. http://****************.com/smile/emthup.gif
Re: (golfa89)
Don't go trashing VW just because you can't keep up with scheduled maintenance. Maybe you should've taken a look at the service intervals required to keep it running right. Go buy a Hyundai. My dad has one and all he has to do it is change the oil and spark plugs
1 - 20 of 27 Posts
