I checked out some brake kits and all in all I found a kit that will work nicely within a 16" wheel, but I need at least a 10 mm spacer to clear the caliper from the wheel spoke. But I clear it by 1.5-2 mm. Is this enough ? I am counting on it since I can go up to 10 mm and not have to perform surgery on my front fenders, all I'd have to do is cut the little lip that is bent inward on the fender off and I'll be ok, along with a little negative camber. The other question is that I will need H & R spacers, but I've never seen a 10 mm one. Anyone have any pics of it ? I know it is hubcentric, but I need to see it to get a better analysis going on paper. I've tried to go with Brembos within a 16" wheel, but I can barely cut it radially, and need at least a 20 mm spacer to clear the caliper axially, so Brembo won't work. RPI Equipped promised me a Porsche Big red (993) kit with reworked hats and brackets so that it will work with my 16" wheels, but so far they've failed getting a rear skin for me in time, along with a supersprint muffler that needs to be replaced. The only other kit I found out that is promising is the AP Racing kit which will work nicely with a 10 mm spacer. Feedback on brake kits please ?
