So I did my searches and came up empty. i have all bolt on and other mods done from sai delete and 2nd 02 and cat delete to upgraded silicone tip 3'dp short ram cold air upgraded dv n75 egr delete delete of all unnecessary vac lines silicone vac lines, water pump timing belt and tensioner done, 2.0 coil packs plugs front mt intercooler, new engine bay wire harness, spec d halo projector headlights, 1 to 4 inch drop coil overs, solid motor mounts, upgraded whole suspension, upgraded brake calipers and rotors, window tint, dbl din touch screen nav dvd cd mp3 mp4 yadda yadda, amp speakers ect. I've gutted everything but the dash, center console, front door cards. left in side Curtin airbags and rear 2 speakers. back upper and lower seats are gone. 100% carpet gone. rear door cards gone, headliner gone, trunk only has a few wrenches a spare tire a small floor jack a qt oil gallon water, a box with extra left over plugs coil packs belts ect.....she has a 1.8t 180hp awp k03s. 02j 5 speed manual. boost and voltage steering column pod with up tp 35 lbs boost gage. stage 3 clutch disk and st3 pressure plate car is 2002 (glx} i believe . { power everything but seats sliding sun roof leather heated heats Cruz control alarm had upgraded sound system with cd player and amp}
now with all that crap out the way I have some simple questions. when i got my tune I went to Ga to do it at Eurotune. they did the APR tunes. i was offered a cheaper tune if i waited 3 hrs drove to the 2nd location for eurotune. it was $320 for stage 2 tune with stock requirements added 30 some hp and hand full of trq. Also added immo sai egr ect ect delete. it was a 91\93 tune with no lift shift. 2 step using clutch switch and max rpm moved up to 7500 rpm I think. i see 23 lbs boost with spikes to 26 and 28, with cheap ebay boost gage. SO TO GET TO MY QUESTION. I have a donor mk4 gti with awp 1.8 turbo. im going to pull just the motor do a complete rebuild with upgraded internals for big turbo. I think I'm stuck on the GT28rs 450cc or 550cc injectors and upgrade the fuel pump. my plan is to run 350 to 400hp max with a roll cage 2 race seats and custom aluminum dash. it will also have upgraded intake cam. so can i make the tune that's on the ecu already work with the gt28rs? just by upgrading injectors fuel pump maybe manual boost controller with or without n75? diode mod? car is straight piped with no 2nd 02 sensor and a "glass pack" at the end. tid car is my baby!!! named her Gaggin Wagon and have the vw symbol and the outer ring says gaggin wagon. i also have the actual vin number plate tattoo as well. tis car will be a family life time car until I wreck it lol. So can I support 350 to 400 with current tune and supporting hardware or do I need a new tune? I just ad another thought and will hit the search bar next, has any one played with twin turbos? small k03s for quick spool off line and gt28rs for big turbo boot and higher HP numbers? does anyone have any other suggestions? input? live in sc or ga and wanna meet up for v dub fun and giggles? i have a few tunes and laptop for 1.8t manuals. also have vcds and obd 11. all help is welcome and thanks for the help!!!
