1 - 17 of 17 Posts
Some kid tried to tell me that if you get bigger wheels and tires, that your speedometer will be inaccurate. Can someone please clarify how the speedometer actually works so I can explain myself to him? THanks
Re: bigger rims = speedo off? (cole)
Simple Really, you speedo if the overall diameter of the drive wheels are taller or shorter than the stock wheel/tire combo, the speedo will read faster (for shorter wheel tire combo) or slower (taller). Its all about the revolutions per mile of the tire. A lotta tire websites actually have a column with the RPM's listed for the different tire sizes, check it out.
Re: bigger rims = speedo off? (LostBoyScout)
o.k bigger wheels = to bigger turning for the wheel therefore your speedometer will be off as for gas consumptiom will incresse because of the added turning radious so you get
+ gas consumption
+ falty readout's on speedo
and i think that is all
Re: bigger rims = speedo off? (Halx)
cole buddy..get 16" rims like mine..better speedo readings and smoother ride..and cheaper tires
Re: bigger rims = speedo off? (Rugrat Anklebiter)
That and if you have big heavy ass 17's your car accelerated like junk compared to the smaller stock wheels.
I think I will no longer go over 16" unless they are really light...
Re: bigger rims = speedo off? (late_apex)
quote:[HR][/HR]205/40/17 is the same exact size as the stock steelies 195/60/14
Yep the exact same overall diameter.[HR][/HR]​
not EXACTLY the same.
195-60-14 = 23.21 inch outer diameter
205-40-17 = 23.46 inch outer diameter (close, but not exactly same as stock)
205-45-16 = 23.26 inch outer diamter (closest to stock)
it is recommended that you DONT deviate more than .25 inch larger than stock.
Re: bigger rims = speedo off? (JetTAFLiTe)
btw, heres teh formula if you dont know it...(for 195-60-14 tires)
195 x .60 x 2 / 25.4 + 14 = 23.21
195: width of tire from sidewall to sidewall. measured in mm.
.60: aka aspect ratio; aka sidewall height. measured as a % of the width ie 60% of 195mm. (multiplied by 2 because there are 2 sidewalls...top and bottom)
25.4: used to convert mm to inches
14: rim size in inches.
Re: bigger rims = speedo off? (Dub n Bass)
Wow Bobby, all that ketchup must be working..I mean green ketchup seems to equal brain power....
Sean
1 - 17 of 17 Posts
