BFI's new Clean Catch Oil Separator functions as good as it looks and without removing the factory PCV. This gives you multiple lines of defense against carbon build up while elevating the look of your engine bay rather than detracting from it.
Their brand new Version 2 design features a perforated cylindrical baffle to maximize the amount of surface area while still allowing air to circulate freely. This allows all harmful oil vapor to collect on the cylindrical baffle, and ultimately drain into the can and not the back of your intake valves.
The new upgraded heat resistant braided hoses give an additional layer of protection and durability as well as make for an extremely OE+ look. Their woven construction, complete with white detail is as factory as it gets.
In addition to all of the new functional upgrades, BFI has also added the ability to customize the look of your car by adding optional anodized
hardware. You can now select from a large range of colors that compliment your build and give that perfect appearance.
Black Forest Industries was the very first company to offer actual OEM hose connections, direct from the supplier who makes them for VAG. They employ a proprietary method to mount them to their hosing to ensure an exacting fit every time, with no third party or unnecessary aftermarket solutions. In this instance, there was no need to reinvent the wheel, so they designed a kit around what already existed for the cleanest possible solution. See more about the Clean Catch kits at  https://store.blackforestindustries.com/
