1 - 2 of 2 Posts
10% Off Dot 4 and Dot 5 Vw Brake Fluid with Code NOV1113 - Expires on 11/30/13
RAVENOL VW BRAKE FLUID
Changing your Vw's brake fluid is recommended and most conveniently done when performing Vw brake rotor or pad service. Did you know that in a 3 year period (average of 15,000 miles a year) drivers depress the brake pedal approximately 225,000 times? Brake fluid is made of a glycol oil base which inherently attracts moisture from the atmosphere. Overtime the brake fluid becomes more contaminated with moisture, changing it's composition and affecting it's ability to stop the car. It also lowers the boiling point of the fluid. This is dangerous and decreases the car's stopping power in emergency stopping situations, where high temperatures are generated from the hot rotors and pads and then into the brake calipers (which function using brake fluid). Vw brake fluid flush should usually be performed every 30,000 miles or 3 years. This is especially important in parts of the country where high humidity is common. Check the owners manual or look at the brake fluid reservoir cap for recommended spec.
Using the correct type of brake fluid is important. Ravenol DOT 4 and DOT 5.1 Vw brake fluid meets necessary fluid specifications. Ravenol brake fluid's additive formulation provides the best braking characteristics in all conditions and offers full lubrication in ABS systems, hydraulic braking, clutch systems, and gives reliable performance in everyday driving or in the frequent braking conditions of extreme stop-and-go city driving. Read more...
Related Brake Repair Kits:
OEM BLAU® Brake Rotor & Pad Replacement Kits
U-Slot BLAU® Brake Rotor & Pad Replacement Kits
Save on other Ravenol of Germany fluids with Code NOV1113 - Expires on 11/30/13
Vw Motor Oil
Vw Gear Oil / Differential Fluid
Vw Automatic Transmission Fluid
Vw Antifreeze / Coolant Fluid
Vw Power Steering / Hydraulic Fluid
Car Care Products
Check Out Our Other November Sales - Expires on 11/30/13
Coupon Code NOV1113 for 10% Off All Ravenol of Germany Fluids
$5/$10/$20/$30 Off BLAU® Valve Cover & Cam Chain Tensioner Gasket Replacement Kits
10% Off Valve Cover Gaskets
$15 Off BLAU® Timing Belt Replacement Kits
$10/$20 BLAU® Tune Up Kits
Website:
www.blauparts.com
* Free shipping offers are for FedEx Ground shipping to 48 US contiguous states only. Offers End 11/30/2013
2021 HiHy Platinum AWD
need to update your title and link.
DOT 5 is not compatible with our brake systems.
DOT 5.1 (in the picture) is.
1 - 2 of 2 Posts
