1 - 1 of 1 Posts
Vw 4Motion Transmission Gear Lube - Semi Synthetic - Ravenol TSG GL-4
Priced To Move! Plus an Extra 10% Off with Code LIQUID14
Ravenol GL-4 Transmission Gear Lube is classified as high performance gear oils. Ravenol gear oils (aka transmission fluid) are specifically engineered for European transmission requirements. Ravenol has formal approvals from ZF transmission, the world largest German transmission manufacturer.
The latest manual transmissions and differential designs require unique performance characterized gear oils to ensure long life performance. Ravenol gear oils provide the proper friction balance required for manual transmission syncros, ensuring smooth consistent shifting, even under high RPM load (racing) conditions. Due to it's unique formula, Ravenol gear oil supplies excellent extreme pressure (EP) characteristics, low pour points with a high viscosity index (film strength), and also provides extreme high pressure absorption (shock load) capacity. Ravenol gear oil is available for hypoid and non-hypoid transmissions, providing excellent aging resistance for extended change intervals. Ravenol gear oil is the right choice in providing maximum protection for your specific European application.
Why Change Your Manual Transmission Or Rear Differential Gear Lube?
Plain and simple, systems with moving parts such as bearings, gears, and syncro rings meshing with one another will eventually require servicing. Over time, metallic particles from the interaction of these parts contaminate the gear lube. Significant amounts of metallic particles present in the gear lube can accelerate wear in the bearings etc. For optimal longevity of both the manual transmission (stick shift) and the rear differential (Quattro / 4Motion / AWD models), Blauparts recommends changing gear lube every 60,000 – 80,000 miles.
Ravenol TSG Gear Lube Information:
Ravenol TSG – Synthetic Hydrocrack Gear Lube - Mfd In Germany
Ravenol TSG 75w90 is a high performance semi synthetic hydrocrack gear lube for manual transmissions requiring specification GL-4.
Ravenol TSG contains high quality synthetic and hydrocrack base oils with a special inhibiting additive formulation to give the ultimate transmission protection in all situations.
Ravenol TSG Features:
Meets Vw / Audi 501 50, G50 specification
Excellent aging resistance
Extreme high pressure capabilities
Optimum viscosity temperature behavior in cold and hot climates
Extreme low pour point
Outstanding wear protection and lubrication in highly stressed conditions
Excellent oxidation, corrosion, and foaming resistance
Suitable in manual transmissions with or without synchros
Other features and specifications:
SAE 75w90
API GL-4
FORD ESD M2C-175-A
GM B 040 1043
OEM Reference: Vw/Audi 501 50 (G50), Vw G 052 911 A2, G 005 000, G 055 726 A2
Blauparts' Popular Repair Kits
BLAU Shock & Struts Replacement Kits
BLAU Brake Rotor & Pad Kits
BLAU ATF Filter Change Kits
BLAU Timing Belt Replacement Kits
BLAU Valve Cover & Cam Chain Tensioner Gasket Kits
BLAU Ocap Complete Control Arm Kits
Ravenol of Germany Oils & Fluids
Website:
www.blauparts.com
*Enter coupon code LIQUID14 to apply an additional 10% discount on select items in our liquidation and overstock category - Offer Limited to Stock on Hand. Free shipping offers on select items are shipped via FedEx Ground to the 48 US contiguous states. Subject to change without notice. Previous purchases are exempt. Discounts cannot be combined. One offer per order.
1 - 1 of 1 Posts
