1 - 1 of 1 Posts
PRODUCT UPDATE: VW Phaeton Timing Belt Kit - 4.2L V8 D2
VW Phaeton 4.2L V8 Timing Belt Kits Now Come With 'Metal Water Pump Impeller'
As of March 1, 2014 all BLAU VW Phaeton 4.2L V8 timing belt kits have been equipped with Graf water pumps. These Graf water pumps offer a cast metal impeller and a heavy duty reinforced pulley.
All Graf VW water pump component are pre-tested to evaluate durability, performance and reliability. The bearings undergo a durability test equivalent to the average water pump lifespan and are then inspected to assess integrity. The mechanical seals are tested in extreme coolant temperature conditions according to predefined coolant water pump cycles. The shape of the impellers are optimized thanks to the use of prototypes in which flow and performance tests are performed. After water pump assembly all water pumps undergo reliability tests using equipment able to determine true water pump performance and reliability. Graf water pumps are manufactured in Italy and are a direct O.E. supplier to many European automotive manufactures. Graf water pumps are engineered and designed to last as long as the genuine water pump you would receive from the dealer.
VW Phaeton 4.2L V8 (2004-06)
GH21617-3-C (Base)
GH21132-B (Enhanced)
GH21132-1-B (Enhanced +)
$15 Off + an EXTRA 5% Off with Code OETIME44
Official O.E. INA BLAU® Audi Timing Belt Replacement Kits
Blauparts' Popular Repair Kits
BLAU Shock & Struts Replacement Kits
BLAU Brake Rotor & Pad Kits
BLAU ATF Filter Change Kits
BLAU Timing Belt Replacement Kits
BLAU Valve Cover & Cam Chain Tensioner Gasket Kits
BLAU Ocap Complete Control Arm Kits
Ravenol of Germany Oils & Fluids
Website:
www.blauparts.com
* Coupon code OETIME44 for an extra 5% off timing belt kits. Offer Limited to Stock on Hand. Free shipping offers on select items are shipped via FedEx Ground to the 48 US contiguous states. Subject to change without notice. Previous purchases are exempt. Discounts cannot be combined. One offer per order. Offers End 4/30/2014
1 - 1 of 1 Posts
