1 - 3 of 3 Posts
Hey dudes, I have a Blaupunkt GMBH Gamma retro head unit without a pin code.
The serial is VWZ1Z3C7105480.
I'm not proficient at EEPROM programming, so I think it's not a good idea to take apart.
I find some code generators on play store and ebay, but I'm not convinced.
Do you know any reliable code app, or method to find out the code?
Thanx guys
I faced the same issue. Used some of the generators, puked out a code and didn't work.
Your best bet is to take out the eeprom and read it out. Sure, it's a tedious job when you don't have the tools or knowledge, but any more experienced electronics guy should be able to do it for you, as it's not more than a 30 minute job.
I ended up doing the same, have a friend that did it for me and the code works. You could also try finding the car's manual, or whatever it's called as usually the code is written somewhere in it originally from the dealer it came from. Good luck
I checked the eeporm reading, but it was not convincing, and of course I didn't want to solder it. The clip adapter would have been about $10 from China, but with a lot of delivery time.
I got my own code from an app on playstore for 9$ 😄
easy peasy 😎
1 - 3 of 3 Posts
