Re: Bleeding ABS brakes... is there a trick? (GetOuttaMyWay)
I have the $40 pressure bleeder from Adirondack. It's really slow with the rear calipers, so I just do a little pumping to help it out. I've never tried it with the car running... I'd be scared about how fast the stuff will come out.
The reason they say it takes a pro to do it is because of the fluid in the ABS pump won't be replaced, unless the pump runs. There's a function on the Ross-tech tool that will run the ABS pump, and (in theory) shoot fluid through the system.
Since I bleed my brakes every 6 months (or before every road course event), I don't worry about having some older fluid still in the pump. It doesn't stay there that long, as I use my ABS extensively.
I am replacing my ABS controller this week.
$$$ And I will have to use the VAG tool, cause the new pump will be full of air.
