Hi folks,
My Passat is in need of new brakes all around - the whole deal, rotors and pads. And since it'll be three years this summer for the Passat, I'll be bleeding the brake fluid and replacing it. I've got a few questions first though:
(Please forgive the duh factor
on this one : )
> When I bleed the brake lines, should I always keep fluid in the system (eg, keep the reservoir supplied with fresh fluid - no air bubbles)? Does anyone try and drain dry (or close to) and then refill, or not? I think the dealer just sucks the new fluid through the lines with the old stuff still in there figuring the old stuff will come out first.
> There's a little screen in the brake fluid reservoir under the cap. If I'm going to suck out the excess old fluid with a turkey baster, how do I get this screen out w/o breaking it? Does it just snap out, or is there some trick to it?
Thanks!
[Modified by SweatSwede, 7:19 PM 4-6-2002]
Thanks!
