BMC CDA, diameter on intake?
647 Views 3 Replies 2 Participants Last post by  JuheeSpeed
70 or 85 mm?
Theres also an VW 1.8T kit that SOME sell.
Whats more in the kit besides the Box?
1 - 4 of 4 Posts
Re: BMC CDA, diameter on intake? (SkodaRS)
At the end of the 'neck', there is a funnel(reducer) glued to match MAF housing.
Funnel's outer diameter is almost the same as the MAF's connecting flange.
Inner diameter is... around 63mm as I remember.
Hope this helps.
Re: BMC CDA, diameter on intake? (JuheeSpeed)
why is that? (the funnel)
IMO, BMC attached it because.....
Without the funnel it cannot be connected by a silicon hose, because the neck is too big to be assembled directly to the MAF.
As you know silicon hose is not that elastic, for it is fabric-reinforced.
1 - 4 of 4 Posts
