got a lot done this weekend.
clutch installed
Untitled by
tim wilson, on Flickr
trans in with the new trans crossmember. my shoulders were blown out after putting this in. it sucked the big one
Untitled by
started working on the mid pipe. needed a third hand to hold the exhaust up while i layed it out and tacked it into place so a stool with a jack stand worked great!
Untitled by
after the down pipe the exhaust runs parallel with the frame rail then at the kink it goes towards the center and then up. gives it great ground clearance in the center of the car
Untitled by
drilled some holes, poked in some bolts and welded them in place for the exhaust hangers
Untitled by
pre made pie cuts came in handy
Untitled by
downpipe fully welded. far from pretty but should hold. definitely have to take some of the scrap pipe and do some practice welds. going to get it ceramic coated along with the manifold and wastegate exhaust
Untitled by
this angle better shows the upward sweep the exhaust makes to tuck it into place
Untitled by
still waiting on a ****ing flex pipe for this section. but you can see the gap has shrunk once everything has been welded up. once the flexpipe is welded in i will recheck my gap here and possible do some minor hammer massaging before getting it coated
Untitled by
full exhaust on the ground. made it in 3 sections. removing just the middle section i am able to service the trans and driveshaft. removing the rear sections i can service the suspension, axles or the diff. pretty happy with it and i cant wait to hear how it sounds
Untitled by
Untitled by
Untitled by
rear section
Untitled by
Untitled by
Untitled by
Untitled by
ground clearance
Untitled by
next on the list is the wastegate exhaust and the intercooler set up. thats gonna be a bitch due to me keeping AC.
