1 - 20 of 36 Posts
http://www.rpi-equipped.com/bonrath.htm
I have neuspeed sport springs installed on my car. I just have one gripe. I don't have the stock raked look that i really like. the neuspeed springs even out the front and back of the car. i was thinking about installing a set of bonrath lowering caps to set the front a little lower. Any pictures, comments, advice would be greatly appreciated. thankyou
Re: Bonrath lowering caps (paul99)
Speaking of lowering caps. Dpes anyone know if these will work on a 93 Passat VR6? I really want to at least even out my front end.
What exactly does it replace. Front strut mounts????
Re: Bonrath lowering caps (selnashar)
I looked into it also, extra 10mm drop will make my PSS9 kit just right....... or .39" should make top of the tire almost even with the bottom of the fender. And for $79 worth it.....
Not doing it till spring
[Modified by ACKTung, 12:17 PM 12-14-2001]
Discussion Starter · #12 ·
Re: Bonrath lowering caps (FastVR6VW)
had them installed on wednesday. I also had a set of bilstein sport shocks installed. I don't know if shocks need time to settle or not but if they don't then these lowering caps didn't lower the car or not. If shocks do take time to settle then i will if the ride height has been affected when i return to the country in about a month.
1 - 20 of 36 Posts
