1 - 4 of 4 Posts
I've been having trouble getting my boost dialed in correctly and I'm wondering if it's been the boost gauge the whole time. It's a Stewart Warner in case that matters.
If it reads 0 when the car is off, does that necessarily mean that it's calibrated? Also, it reads -19 at idle, is that normal?
Re: boost gauge calibration (allmotor6)
yeah thats completely normal. when the car runs it means its in vacuum, when the car is off or theres a vac leak the gauge will read 0. if the car is running and you ever see the gauge go to 0 without boost, you have a vac leak, just a little fyi
chad
Re: boost gauge calibration (GLI_jetta)
same thing with mine, it still gives the same readings as it did before.... but now when the engine is off the needle is point at about +2 psi.... but again when running the readings have not changed everything is same ol' same ol'.....is there a way to recalibrate, or is it necessary if the readings haven't chagned?
1 - 4 of 4 Posts
