1 - 14 of 14 Posts
shouldn't my guage read 0 when i blip the throttle in neutral? possible leak maybe?? it's only showing -10. any thoughts/suggestions? thanks
2005 S2000, 2019 G70 6MT, 2019 i3 REX, 2003 XC70
Re: boost guage not showing "0" when rev in neutral...HELP! (MacPhstoU2)
No, not necessarily. As long as it reads -22 In Hg at idle and you don't hear any leaks under boost, you should be ok.
-Nick
Re: boost guage not showing "0" when rev in neutral...HELP! (GTI 20v)
quote:[HR][/HR]No, not necessarily. As long as it reads -22 In Hg at idle and you don't hear any leaks under boost, you should be ok.
-Nick[HR][/HR]​
Discussion Starter · #8 ·
Re: boost guage not showing "0" when rev in neutral...HELP! (Adam20v)
here's the thing- when i rev past 4.5k, it hits zero, and if i rev to 5k, it shows 2 psi. of boost. it's ust when i blip the throttle, it will not reach zero. other than that, the car runs great. i spike 19-20 psi and hold 16. my mods are UP chip, hyperboost dv, and intake....
Re: boost guage not showing "0" when rev in neutral...HELP! (judoGTI)
-22 in neutral at idle when warmed up. And my gauge goes right to 0 when I do a slight rev. And if I rev it high, I get to 2psi or so. So I say it's perfectly normal
And no I don't have a leak.
Re: boost guage not showing "0" when rev in neutral...HELP! (AVANT)
I'm wondering if altitude has anything to do with it? Since I'm in the mile high city, would the vacumm show less?
I'm really curious if I have a leak anywhere.
1 - 14 of 14 Posts
