Hey everyone, I own an 05 GTI 1.8t, the ecu is chipped with the GIAC X+ program. Other mods are intake, forge race dv, 2.5" catless downpipe. The car spikes at 22psi and holds in 1st gear to 5k then bleeds off to 16psi. Second gear does the same but bleeds off to 16psi around 5500rpm. 3rd gear holds 21-22psi all the way to 6100, and 4th and 5th hold through the entire rpm range. My question is why is the boost bleeding off? I've checked all connections/hoses in the car and everything is solid. Wastegate actuator problem I assume? Is it the N75 valve? I'm clueless and it frustrates me because it would be nice to hold 22psi through 1st and 2nd, the strongest gears.
If there is any way to hold that boost level please help me out. Thanks everyone...
C-
C-
