Bosch HID ballasts
1469 Views 13 Replies 6 Participants Last post by  PoleZero
Anyone know where I can buy a set of Bosch HID ballasts and wiring? Or anyone with any knowledge of how the ignitor coil works? Thanks in advance
PoleZero
1 - 14 of 14 Posts
Re: Bosch HID ballasts (PoleZero)
do you want a kit or jsut the ballasts?
what lamp are you putting in?
Re: Bosch HID ballasts (HIDGolf)
quote:[HR][/HR]do you want a kit or jsut the ballasts?
what lamp are you putting in?[HR][/HR]​
I have the Bosch OEM HID lamps, but the German seller did not ship the ballasts and wiring with it, so I'm SOL. The part number on the back of the left one is 1J1 941 015 L. So I am looking for the OEM Bosch HID ballasts and the wiring for the ballasts and also the adapters for NA spec halogen lamps if possible. Thanks
PoleZero
maybe you can contact http://www.pgperformance.com, or http://www.parts4vws.com they should have them.
quote:[HR][/HR]Anyone know where I can buy a set of Bosch HID ballasts and wiring? Or anyone with any knowledge of how the ignitor coil works? Thanks in advance
PoleZero
[HR][/HR]​
Why do you want Bosch? some special reason?
PoleZero
[HR][/HR]​
So what DID you get from this German?
Also what car do you have?
Re: Bosch HID ballasts (Cullen)
Also what car do you have?[HR][/HR]​
I have the left and right light assemblies, part numbers 1J1 941 015L and 1J1 941 016 L respectively. The light assemblies include the headlight housing, the ignitors, the leveling motors, the HID bulbs, blinker bulb, high beam bulb, and the left one has the leveling electronic module. I have a 2000 GTI VR6. The reason that I chose Bosch is that they are OEM. Thanks
PoleZero
PoleZero
[HR][/HR]​
Yes Correct! Now was the guy selling them withOUT the ballasts or?
BTW this might help you: http://bambergvr6.50megs.com/HID_wire.htm
BTW this might help you: http://bambergvr6.50megs.com/HID_wire.htm [HR][/HR]​
He was selling them complete on eBay. It was the Enrique guy. I guess he is being prosecuted by the German government right now, as he also jipped a German guy. I just wanna get some working lights. Thx for Roger's links I've been there already though. I emailed him but I'm sure he's busy with his move and all so I might try for a response when he's settled in.
I could use Philips ballasts and chuck the ignitor and stuff, but then it's kinda.. crappy, non OEM. I want to see if it's possible to get some Bosch ballasts for a decent price, if not I might do the Philips thing.
PoleZero
PoleZero
[HR][/HR]​
Well I would recomend you scan this forum:
http://www.lighting.philips.com/forum/forum_6/wwwforum.cgi
See less See more
what is a ballasts? are they actuall headlight assemblies or what? how much would it cost for a kit of hid's??
Cullen how much for the 1/2 smoked tail lenses on your site?
[Modified by VictorRyan6, 7:49 PM 11-30-2001]
Re: Bosch HID ballasts (VictorRyan6)
quote:[HR][/HR]what is a ballasts? are they actuall headlight assemblies or what? how much would it cost for a kit of hid's??
[Modified by VictorRyan6, 7:49 PM 11-30-2001][HR][/HR]​
If you are refering to the A2 lights? See my signature and the prices should be shown in the photoalbum!
Hey Polezero, what do the ballast for this setup look like? I have a pair of Bosch ballast from a 2000 Mercedes S-class. The housings are 4" X 3.5" X 1.5 deep. They have a 6 pin horzontal female connector approx. 1.5' wide. I don't know if these are the same, but could be. I also have a set of Honda S2000 Xenon ballast w/ignitors & a set of seperate ballast/ignitors from a 2000 Acura TL if interested. These are pretty nice since the lead off the ballast is about a foot long, & the lead from the ignitor is about 8 inches....good for tight mounting locations.
Re: Bosch HID ballasts (neubeet)
quote:[HR][/HR]Hey Polezero, what do the ballast for this setup look like? I have a pair of Bosch ballast from a 2000 Mercedes S-class. The housings are 4" X 3.5" X 1.5 deep. They have a 6 pin horzontal female connector approx. 1.5' wide. I don't know if these are the same, but could be. I also have a set of Honda S2000 Xenon ballast w/ignitors & a set of seperate ballast/ignitors from a 2000 Acura TL if interested. These are pretty nice since the lead off the ballast is about a foot long, & the lead from the ignitor is about 8 inches....good for tight mounting locations. [HR][/HR]​
I don't know how big the Bosch ones are that go with my lights, but the connector is a 4 pin off of the headlight assembly. Two wires go to 12V(low beam) and ground, and two wires go to the ignitor. I'd be interested in buying any of those, preferably without the ignitors because I already have them. Do the Bosch ones have ignitors with them? Email me at [email protected] with prices for the above items. Thanks!
PoleZero
See less See more
1 - 14 of 14 Posts
