This is a build thread / work in progress
This thread took a different direction and I ended up going with a hybrid setup instead of a BT
Table of Contents
The top end had been rebuilt around 72K as the previous owner broke the timing belt. Water pump and normal goodies were replaced as well. A new ragtop was installed a year go as the OEM back window fell out.
The 2 hour ride home after buying the car was a bast! The following morning I was off to have the APR stage 1 software tune. I also did new plugs and Forge DV to replace OEM. That day I took a 150 mile road trip and threw my first of several P1128 codes. Over the next week (every 100 miles or so I would get a CEL)... Which made sense.. More boost is going to push the already weakened vac system beyond the limits
I have since ordered silicon to replace all stock vacuum lines and will smoke check when everything is back together. Also have an in-vent boost gauge on the way to keep an eye on what is going on under the hood easier.
The car had the broken glove box (which was easily fixed for free with a screw I had laying around)... and the pixelated LCD syndrome. I have removed and disassembled the cluster to replace all guage motors and the LCD panel with brand new components I sourced on the web. I should have that back together by the end of the week and will post the results when done.
Updates so far include:
Stage 1 APR
Forge DV
42 DD intake
While this info above doesn't pertain to the long term goals I have for this car.. It helps set the stage for where it started
The car is really fun to drive and gets great MPG on highway.. But sometimes "fun" just isn't enough
Over the next year or two the plan is to upgrade the cooling system, suspension, brakes, fuel delivery, differential controller, built motor, big head, big intake manifold, exhaust and then turbo... Pretty much in that order.
The details will get filled in along the way and documented for all to see, but my goal is to top 400 WHP and still maintain an OEM look.
I appreciate all visitors and advivce any experienced vets have for someone on my journey. Stay tuned and thanks for dropping by.
-Tony
Table of Contents
- Cluster Teardown
- Waste gate spring mod
- ECU, Cluster, and RFID (key) swap
- Short shifter install
- Billet injector cups install
- Front mount intercooler
- Catch Can install
- ECS Ultimate dogbone mount
- Install Rear springs shocks and lateral links
- Removing front suspension
- Manual boost controller install (n75 delete)
- MTX-L Wideband O2 and Gauge Install
- Haldex Service
- Waterfest 2013 Drag Times
- Powerflex Strut Bushings & Adjustable sway links
- 034 Motorsports big port manifold install
- Mishimoto Radiator Upgrade
- TyrolSport brake stiffners
- Baseline Dyno run on APR tune
- GTS Hybrid turbo swap
- Wideband conversion
- 42 DD turbo back install / Defcons / front & rear sway bar upgrade
Stage 1 APR
Forge DV
42 DD intake
-Tony
