1 - 7 of 7 Posts
my speedometer's needle has been hoppin ever since i busted my axle. i got another one on, but it still bounces, what gives, is the speedo just dyin or what? thanks for any feedback
Re: bounce baby, bounce (YourHondaIsPoop)
i had replaced my gauge faces in my cluster, which required taking the speedo needle off. once i put it back on, it was accurate, but bounced a little from 0 to about 20 miles an hour. maybe somethings just loose in your cluster?
Re: bounce baby, bounce (NastyJettaNza)
Quote, originally posted by NastyJettaNza »
I have busted 10 maybe 12 axles and never had this problem umm....maybe it is coincidence.
me too and never had that problem
12 Golf 2.5, 99.5 Cabrio GLS
This happened to me too. At first, it looked like the circlip that holds the gear to the cable had dissapeared. It still did it after I fixed it, it turned out to be I hadn't secured the cable to the cluster all the way. If it easily pulls out it has'nt clipped in all the way.
i ran tri-flow down the cable on my old gti, it helped alot with the bumpy needle.
1 - 7 of 7 Posts
